1970 F100 Build Crown Vic Swap
Old 09-28-2012, 09:18 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
Starting the restoration on my 1970 F100 SWB, putting an 04 Crown vic front suspension under it
Old 09-28-2012, 09:27 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
Old 09-28-2012, 09:36 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
Doner 04 crown vic for front suspension
here it is out and cleaned up a lil
front cap finally off
Old 09-28-2012, 09:50 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
This is one way to lift the cab off lol
Old 09-28-2012, 03:35 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
Looking great! Mine is a '70 also. What are you doing for the rear suspension?
Old 09-28-2012, 05:03 PM
70f100bb's Avatar
70f100bb
70f100bb is offline
Undecided on the rear suspension right now, gonna stick with leafs, but I'm either gonna go with an explorer rear axle but then I gotta order custom backspaced rear wheels, if I use a certain wheel then I gotta find a 65" wide axle, then ill re drill the right bolt pattern in it to fit my wheels, I think an older f150 axle is close to that that I need
Old 09-29-2012, 05:57 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
Got the motor and trans pulled out of the frame yesterday
started cutting out old crossmember and spring buckets
Got the new just setting under there, gonna be easier to install this then it was to remove all the old ****, took alot of cutting and air chiseling to get them old rivets out
Old 09-29-2012, 11:17 AM
Nighteyez's Avatar
Nighteyez
Nighteyez is offline
Excellent thread
Jim
Old 09-29-2012, 01:17 PM
elgemcdlf's Avatar
elgemcdlf
Ain't that the truth! Drilling the mounting holes is fun though. You have the advantage of flipping the frame over which will make it easier.
Old 10-01-2012, 06:06 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
made the spacers to bolt front end in
got it bolted in and the spacers tacked in, now gotta take it all back out to weld it up good and box the frame
Old 10-01-2012, 10:46 AM
Nighteyez's Avatar
Nighteyez
Looks good so far. Boxing the frame is something I want to do to mine when I can get to it.
Jim
Old 10-01-2012, 01:36 PM
67-F100's Avatar
67-F100
67-F100 is offline
looks good! i wanna do CV front suspension on my 67, what year CV can i get it from?
Old 10-01-2012, 01:37 PM
elgemcdlf's Avatar
elgemcdlf
'03-'11 are the years to look for
Old 10-27-2012, 03:26 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
fixed body mount
rear mount of the lower control arms on
frame ready for sand blasting
Old 10-27-2012, 03:29 AM
70f100bb's Avatar
70f100bb
70f100bb is offline
got frame back from sand blasting, ready to get some work done on it
Quick Reply: 1970 F100 Build Crown Vic Swap
