cant find obd fuse location
i dont think our fords have an obd fuse. tee-hee-hee.
but dont fret. ur obd fuse is usually shared with the cigarette lighter, i tink. u find tat fuse for the cigarette lighter, then ur alright, cos i believe the wiring is such tat they are conjoined. funky word, but it grows on anyone. "conjoined". lol.
cam sensor and crank sensors dont usually give out tat quickly. usually it's the fuel filters, oil filter, FICM, batteries, alternator, and even the egr valve tat die out before them fellas do.
have u load-tested ur alternator? over 12 volts? good.
load-tested ur batteries yet? they have to be load-tested individually, cos they're arranged in parallel mode. disconnect one to test the other. ideal voltage is usually 12.6 volts for good battery.
then test ficm. we have a test procedure in our tech folders. for me, i have a scangauge. hence, i program the parameters for FMP (ficm main power). i find out real quick if she's alright or not.
oil filter. did u use the motorcraft one? i recommend u do. them generic ones dont work on our trucks.
fuel filters. did u change them out? they're supposed to be changed BOTH at the same time. every 15,000 miles.
this is a funny thing, but if she had "died" before from a major problem, like blown egr cooler and blown oil cooler......... maybe u could try hitting the fuel pump reset switch. it's over by the kick panel underneath the passenger side glove compartment.
dont quote me on that, but u could try and see if that works. if all else fails, no offense, but ur truck aint gonna be starting anyway.
sorry to hear tat, man. just hang in there. i'm sure a solution will reveal itself. it'll work out in the end. keep the faith.
if u or anyone else uses a FRAM oil filter, there is a very good chance ur truck aint starting is cos of that. it's a strange theory but tats how the cookie crumbles. only the motorcraft and wix oil filters are recommended for our trucks. the 6.0 is tat frigging sensitive.
