F-1 Transmission Swap
Folks,
Greetings from Western Canada.
I have a 1951 Ford F-1 with a 1968 Mustang 302 engine and a 3 speed (on the floor) transmission.
The engine is great, The transmission, well that is the reason for this post.
The current 3 speed has the shift linkage on the left side of the transmission case. So far left, it is under your right leg in the 1st - Reverse shifts.
I have contemplated a 5-speed on the floor as well as an automatic with overdrive.
What have others done? What is the best combination?
If I go with the automatic with overdrive, can I keep the shifter on the floor??
I would value any and all input.
Thank you.
Take care.
Tug
Thank you.
Take care.
Tug
T5 from a Mustang with a Chevy S10 tailshaft housing to bring the shifter forward.
OR
AOD from behind a V8 or from a truck from model years '88-'93.
You can install a floor shifter with any automatic.
There is a thread or two on here about the T5.
I'll spend about 90 seconds searching and post a link if I find one.
OR
OK this is for the T5 behind a flattie. There is still trans, shifter and cross member info of interest:
https://www.ford-trucks.com/forums/4...pter-info.html
Several links to T5 info here:
https://www.ford-trucks.com/forums/8...n-my-56-a.html
You are not alone:
https://www.ford-trucks.com/forums/8...for-302-a.html
https://www.ford-trucks.com/forums/7...r-a-302-a.html
Some good links:
https://www.ford-trucks.com/forums/5...y-in-f100.html
You are not alone:
Some good links:
trucklady
Car/truck Buying Advice
09-23-2004 12:11 AM
