HPO crossover ?
I've read that it can smooth out idle and help get oil to, I think it was #8 injector As far as being necessary, I don't really know, but I wanted to do a gauge so I thought I'd do it like this and have both. Besides, how much of the stuff we do to these trucks is really "necessary" LOL!!
I know the SS HPX that Clay sells is a hard line, but can this be made with 5000 psi stainless steel braided hydraulic hose? I have some #5 o-ring fittings that I got to do a HPO gauge, but I was thinking about doing a crossover and tee the gauge in the middle of it. Will this work?
on
1 Post
Mine is a flex line I got from dieselsite. I've heard of the hpop lines being made, I don't know why you couldn't make the crossover, as long as its made for high enough pressures. I don't think I'd tee into it though, I think I'd just use one of the other plugs in the head for the gauge. JMO though. Put your plugs and orings in the glovebox, just in case.
Thanks guys.
on
1 Post
Aaron, you'll have to send me some info on the electro rust removing tank.
When I bought the Adrenaline, Bob at dieselsite told me to get rid of the HPX hose, its not needed because of the design of the pump.
When I bought the T500 Joey told me the same thing, built into the design of the pump each rail get equal pressure ensureing #8 cylinder gets its fair share of oil.
on
1 Post
Its awesome bill.I have a 55 gallon plastic barrell.One table spoon backing soda per gallon water.piece od 3/16 x 4 steel (or stainless lasts longer) running down one side of barrel(to recieve the rust) it is sacrifical and the pos connects there.negative hooks to the part being derusted.battery charger on 2 amp setting and away we go.I have a 8" ford rear housing for my 41 derusting the inside of a very ugly situation..first end in and two days later it looked like new inside and out.tomorrow the second end comes out and i start on axles.i will post a pic of my rig if it is light enough when i get home.I have lots of parts to clean.i hope this battery charger holds up lol!
#28
I wish i could take credit for being really smart.Im not,i have several friends that have small ones and there is lots of info on the net if you search the topic.I am always amazed that not alot of people know it can be done so easily.I tell anyone i can because it is low buck and works well.my rear end should be done tonight,then onto model T leaf springs this weekend.there a lot of pieces to be cleaned!
#29
