F350 no boost till 2000 RMP
Try pulling the egr valve and take a look at it,may be as simple as just cleaning it. Also while its off, look down in the manifold and check for coolant in there, just to be sure. A sticking /bad valve would throw a code tho, like p1335 or p0404, if those are the new codes you get definitely check the egr valve.
I believe p0299 can be related to a few things, ill be honest i dont know a whole lot about it. I have read it can sometimes be related to a clogged EBP sensors or leaking cac boots.
Grab the other code it threw and ask this question in the 6.0L section, there is a lot of knowledgeable people on there.
edit
Just found this video on youtube, some good information on p0299 check it out.
http://www.youtube.com/watch?v=q5Py62-cWSQ
edit
