F-1 Transmission Swap
Old 09-26-2012, 11:40 PM
Tug Hercules's Avatar
Tug Hercules
Tug Hercules is offline
Folks,
Greetings from Western Canada.
I have a 1951 Ford F-1 with a 1968 Mustang 302 engine and a 3 speed (on the floor) transmission.
The engine is great, The transmission, well that is the reason for this post.
The current 3 speed has the shift linkage on the left side of the transmission case. So far left, it is under your right leg in the 1st - Reverse shifts.
I have contemplated a 5-speed on the floor as well as an automatic with overdrive.
What have others done? What is the best combination?
If I go with the automatic with overdrive, can I keep the shifter on the floor??
I would value any and all input.
Thank you.
Take care.
Tug
Old 09-26-2012, 11:48 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
T5 from a Mustang with a Chevy S10 tailshaft housing to bring the shifter forward.
OR
AOD from behind a V8 or from a truck from model years '88-'93.
You can install a floor shifter with any automatic.
There is a thread or two on here about the T5.
I'll spend about 90 seconds searching and post a link if I find one.
Old 09-27-2012, 12:06 AM
85e150's Avatar
85e150
85e150 is offline
9.ford.5
Canadian National Chapter
12-12-2008 09:57 PM
MuddyAxles
New York Chapter
09-07-2007 05:40 AM
trucklady
Car/truck Buying Advice
09-23-2004 12:11 AM
Quick Reply: F-1 Transmission Swap
