1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
61 Rear end rebuild
Old 09-25-2012, 11:44 AM
Justin Smith's Avatar
Justin Smith
Justin Smith is offline
61 Rear end rebuild
Anyone know what gear ratio i should put in it for more gas mileage/top speed? i dont know much about gear ratios and such, id gladly appreciate the help.
Old 09-28-2012, 09:39 AM
cobraguy's Avatar
cobraguy
cobraguy is offline
Justin welcome FTE. A little more info would be helpful. Things like what truck you have. Engine size, transmission, stock or modified, what rear end, intended use, all comes into play when selecting a gear to make the most of what you drive and how you drive it.
Old 10-03-2012, 10:31 AM
Justin Smith
Its a 61 f100 unibody, 292 y block, 4 speed, 9" rear end, and im gonna just build it to be a weeked/casual truck, something i can just go out and cruise around in but id like a decent top speed.
Old 10-05-2012, 09:27 AM
cobraguy's Avatar
cobraguy
cobraguy is offline
If you run 235/75/15 tires you can get away with gear ratios as low as 3.00-1 but you start working it real hard at the higher speeds. My 61 uni had 3.89-1 with a 292 2bbl and granny 4spd and 31" mudders. It topped out at around 75MPH. It got 14MPG on a trip from Tacoma to San Diego averaging 60MPH with 1/2 ton of stuff in the bed.
64F-100
25
07-18-2009 11:30 PM
srercrcr
10-07-2008 07:36 PM
andrewasl
07-23-2006 08:39 AM
ramtoo
10-05-2005 07:16 AM
Sam_Fear
11-20-2004 03:05 AM
Quick Reply: 61 Rear end rebuild
