I'm getting a code of 4 flashes, then a pause, then 7 flashes at startup. Then it sets solid. Anyone have any idea what this means?
No fuses blown or prior ABS light on this vehicle.
Thanks
You will have to a scanner that can pull ABS codes, most cheap scanners will not pull ABS codes. I do know about the only parts house that has it is Oreilys and the scan for free. Good Luck, hope this helps.
Thanks! I'll drop by there in the morning. I have a scanner but it won't pull ABS codes, already tried.
