I checked it today. The passenger side rear cab mount has collapsed, all the rubber is gone, which caused it to pull up on the other side. I think a set of body mounts will fix it right up.
For me it was a bent frame. Be sure to check that out sooner than later.
I thought you said in your original post that you checked the cab mounts and they were okay..... That's why you got so many different replies and possibilities. Everybody is just trying to help.
I checked the cab mounts.. worn out but not the problem.
