safe to idle for 5 hours in the cold???
I am figuring out how I will keep warm in my truck when I sleep while delivering rv trailers. To expensive to get rooms for a few hours. I can't use a 12 volt heater cause it runs down the battery and a small generator is loud but I've heard that idling these 7.3 idi isn't the best thing do do. It will be cold outside so it shouldn't overheat
I second that, my previous 88 7.3 was horrible inside the cab with the windows up. that would be my only concern.
You can rig up a manual override for your fast idle pretty easily, it would just require a diode to keep your jumper power out of the cold advance or set them on separate switch. Adjust the fast idle solenoid out to about 900 to 1000 rpm and you should be okay. I set mine to 1100 when its dead cold out.
Smelly diesel exhaust in the cab is a giveaway, but remember that you can't smell carbon monoxide, so just because it smells ok in your cab does not mean you're in the clear. Go to the hardware store and get a carbon monoxide detector and set it on your dash. You owe yourself and your loved ones this 35$ favor!
If you're delivering RV trailers, don't any of them have heaters inside? Might also be more comfortable than crashing in the truck. Also maybe cheaper than burning all the diesel idling.
Just a thought... You might not be able to for a thousand reasons, but I figured it would be worth a mention.
If your serious, and sleep in your truck alot; consider one of these.
Webasto - Air Top 2000 ST for Light-Duty Commercial Vehicles
They're spendy, but save lots of fuel and wear, and make amazing heat.
