2005 F150 5.4 FAIL SAFE MODE
Old 09-13-2012, 09:37 AM
Peties3's Avatar
Peties3
Peties3 is offline
HELP PLEASE:
When I was leaving work last night, went to start up the truck and had no throttle response and fail safe mode displayed on the dash.
Truck would not move at all. disconnected the battery and then turned on the headlights to drain residual power, reconnected battery. Still the same thing. I got the usual codes:
P2104 forced idle, P2106 forced limited power, P2111 TB stuck open
Truck is currently getting towed to the dealership and will get more info. from them later.
Anyone here have any ideas as to what happened to this truck just sitting? Fine one moment, dead the next! codes will not reset nor did the disconnect on the battery work.
HELP!!!!!!
Old 09-14-2012, 08:45 AM
Peties3's Avatar
Peties3
Peties3 is offline
Well after $600 at the dealership. It is now back on the road. I generally try to do my own repairs on my vehicles but in this situation, the truck is in another city than where I currently reside. So it was towed to the shop and repaired there.
Since there was no response to this post, the community seams not interested in what was the problem and possibly save someone else all the headache and lightening of the wallet that I just went through.
Old 09-14-2012, 04:07 PM
Bent6's Avatar
Bent6
Bent6 is offline
Really? You gave it less than a day to get a reply. Maybe people should make up answers just so you have something to read. Obviously you're not interested in helping others unless there's something in it for you first.
Old 09-14-2012, 04:26 PM
tharepairguy's Avatar
tharepairguy
tharepairguy is offline
The post was up for less than 24 hours and your all butthurt? I try to look at most of the threads and if I do not have anything to offer, I say nothing. Hopefully it cost you a lot to fix and here's to you needing more repairs in the future...
Old 09-14-2012, 08:17 PM
02transam's Avatar
02transam
02transam is offline
I am going to say it was the throttle body............
Old 10-11-2012, 10:39 AM
truwest1's Avatar
truwest1
truwest1 is offline
I took off the 4 bolts on mine, cleaned it with gun solvent and put it back on. Problem solved. Course the other things a year later weren't so good....see my posts for the hell.
kevinjackson94
01-06-2015 09:34 AM
D Lab
Escape & Escape Hybrid
03-27-2014 01:04 PM
bedrock2004f150
Electrical Systems/Wiring
03-04-2012 03:00 PM
prostreetranger1
1999 to 2016 Super Duty
12-15-2010 06:12 PM
rbachmann
1978 - 1996 Big Bronco
10-18-2004 02:41 PM
Quick Reply: 2005 F150 5.4 FAIL SAFE MODE
