Rear Fender Brace Question
Hello FTE Friends,
I'm at it again...
In the garage making things happen on the truck! Woohoo, God is good!!
Okay, so I have finally found my rear fender braces / brackets and find myself looking rather dumbfound as to where these should attach to. I know where they attach at the fender side, but not sure after that. The obvious is sometimes too obvious. Since there is no bed wood yet, I don't want to use up a bedwood bolt location. That may seem important later.
I know some of you have the answer - with pictures, for my veiwing pleassure.
Also, if anyone of my FTE friends can provide me with how in the heck do I install the outside door handles, that too would be really appreciative.
Hurry before it gets too hot again!
Paul
I'm at it again...
Paul
Hello FTE Friends,
I'm at it again...
Paul
I'm at it again...
Paul
|edit correction, I could have sworn chassis... only one of my 4 trucks has these, been a long time
as for the door handles.. remove the linkage inside,
pull back the door gasket at the handle to find the handle retainer clip, and pull it out of the door..
Sam
Thank you TruckeeMtnFords. I appreciate that clarification. After Sam's note, I began to look very carefully and the only place logical it seem to fit is where you mention.
Thank you, thank you & thank you!
Paul
