Is there a difference between power master cyl and manual master cyl?
I have been trying to figure ut what is wrong with the brakes on my 62 Uni. I installed Speedway's disc brake setup on the front of the truck and Wilwood's new adjustable Proportioning valve and a new dual master cylinder. I have bled everything several times,have great pressure at rear but not at the front. I have adjusted the valve in to take away pressure to the rear to no avail. I still have a crappy pedal. I can pump it up but that will not work on the street.
My question is there a difference or do they make a specific dual manual master cylinder for these trucke? The master cylinder I installed is from a CPP power brake setup but the booster will not fit with the brackets I have. I was going to use it on a 55 Chevy I had but since sold it so I had this sitting around and thought I would use the master cylinder on the truck. Now I am wondering if maybe a master cylinder that was being used in a power brake setup may not work in a manual setting. What do you think?
I am thinking I will just change out the master cylinder. Do I order one for a 72-79 F100 with manual disc brakes?
GJCAT
01-18-2018 03:58 PM
mudrunner4ever
04-05-2013 06:35 PM
Pappys53
10-07-2008 06:39 PM
geaux tigers
12-07-2006 05:48 AM
DJOHAGIN
11-15-2006 11:20 PM
