3.55 to 4.56 swap
I can't answer those last two questions but I just remembered a little tibit that might ease your gear swap. The D44ttb has a center section that comes out as a single unit. Ring, pinion, spiders, all together in the third member so you could just order a whole third member with 4.56 gears and a LS or whatever you want and bolt it right in without having to set the gears.
yea i seen that i can get the whole deal but i think im just gona put the gears in with a locker in the rear and ls in the front. also would u recommend i get the kit to rebuild the front and rear like the bearings and seals and all that stuff none of its leaking and iv never had a problem with any of it so far so i didnt know if i should just leave it and put the gears in and call it done or go ahead and put new seals and bearings in 2
GuitarJesus
12-03-2016 02:14 AM
Dan Drover
04-08-2015 09:10 AM
itcowboy
11-26-2007 11:04 PM
