Best place to buy wheel bearings?
Hey guys, I have to buy wheel bearings again for my Superduty. I have replaced them every 15-20k miles. Has 35s and 10" wide wheels so I guess is why it wears them out so fast. I have been buying these off brand wheel bearings off of eBay for the past few times. Have you had any luck with certain brands. Oem from ford is outrageously expensive. What have you bought?
Ebay is not the best place to get one.
Check these guys out They are also a sponsor
Tousley Ford Parts Depot
the larger tires don't help. You could also check with
http://www.summitracing.com/
Sean
Sean
Some of the best prices I found are from RockAuto Auto Parts Timken and SKF make a quality bearing better off with them than cheapos.
If you have the extra money you could always eliminate the stock unit bearings with a Spyntec conversion kit. It replaces the stock unit bearings and hubs completely with more robust and serviceable tapered roller bearings spaced a lot wider than the unit bearing for more support. I believe Yukon makes a kit also. There are two downsides to this kit though. 1) Price
2) Manual hubs only.
Pirate4x4.Com - The largest off roading and 4x4 website in the world.
Spyntec Lockout Hub Conversions
on
preppypyro
29
11-10-2012 03:46 AM
