1975 Ford F250 Highboy 390 to 429 swap
there is yet another option ...... you can use the 390 perches and stock 390 motor mounts i use these on my 420 hp 460 in red dawg and most of the mud trucks run these too.... my cousin Nathan has a NASTY 429 that he has ran for years with stock 390 motor mounts i have some pics and the other side http://www.uscconlinealbum.com/lifec...?th=450&tw=610 and my crude drawing of where you need to cut the motor mounts to make them fit and the 2 bolt holes on the 429 block you will need to bolt to (note you have to drill one of the holes a little larger on the 390 motor mount) this is at least what i would suggest to you since 390 motor mounts are only $15-$20
StarScreamin
12-18-2018 05:05 PM
ddsprint
06-27-2008 07:44 AM
Rancho*Ryda
Engine Swaps
01-19-2005 06:07 PM
