Lifting my truck
Lifting my truck
Hey guys and girls, I have a 1987 Ford F150 4x4 4 speed with the 4.9L. I'm from Alabama and you never needed a huge truck there. You can't fit in the trails. You risk rolling over. Etc. All you needed was nobby tires because of the Clay and suspension that could really flex. But I live in South Florida now and despite how boring and pointless it is to go off roading here I still do it. and really all you need is a snorkel, a huge lift, and some big ol' tires. SO! I would like to lift my Truck. The cheapest way is fine. Dont argue with me haha I'd like to get enough lift to get some 38's on there. but with enough room to flex still. Doesnt have to have a 30 foot gap in between the fender and tire but you get what I'm saying. What parts and such are needed (cables, steering, etc) and how much do you reckon this will cost minus labor. I guess atleast 8'' huh. Don't worry about wheels and tires. Thank ya!
do a body lift just spent this weekend making a mud truck all it had was a 5 1/2" body lift and it and it has 40's under it we used 4x6 square tube cut about 6" long and used new cab and body mounts only changes we had to worry about is shifter linkage(longer cable for auto) , steering shaft adaptation, and electric fans cheapest and easiest way we have found and our entire county is full of trucks like this but its your choice
This is what you need.
Skyjacker Suspension 80 96 Ford F150 8" Kit w/ Arm w/o Shocks
Go with a 6" lift kit with a 3" body lift but some of the cheap body lifts do not come with a rear bumper bracket to raise the rear bumper though , good luck ! Also good choice in Florida, Ilive in central Florida , and good luck with your lift , also you might want to look on craigslist.org for a donor truck that is lifted, I see some in my area sometimes at good prices!
An 8" lift would be cool and all, but get an F350. You're just going to be wasting money putting parts into the half-ton drive train. The Dana 44 TTB can only support 33" tires off road, and the Dana 50 TTB (as seen in an F250 4x4) can only support 35" tires for long periods. The Dana 60 will easily support 38" tires without breaking every time you hit a bump. You won't have to lift it nearly as far, probably only 4" or so. And you'll save money in the long run by not having to replace parts every week.
I actually recommend it quite often. If you're gonna end up swapping most or all of the drive train, might as well find a truck that already has most of the stuff you're looking for. Or find a truck that isn't running and swap the stuff into that instead of tearing apart a perfectly good truck.
I was wanting to swap 1-ton axles, big block, th400 trans, and NP203/205 stacked boxes into my blazer but it already has a crate 350 and rebuilt 700r4 and the body is in good shape. Figured I could spend an extra $500 and get a blazer that needs a new engine or trans and keep my perfectly good blazer for DD duties.
Guys c'mon, Give him a break. All he wanted to do was find the cheapest lift for his truck. I6, I'd go with a 6inch lift and just stay with 33's. If you use 33's you won't need to re-gear, heck you could run 35's but its just going to be stuffed. Use that on the trails until you can buy a dedicated mud truck. That's how we do it here in florida. Plus, there are plenty of trails and mud holes that wont swallow an F-150 with 33's.
6" lift from rough country:
Ford Suspension Lift Kits
Oh okay, well when I save enough to buy a F350 4x4 with a 460 in it and money to lift it and put wheels and tires on it..... Then I will lift my truck. thanks man. such a big help. Because I can go out and buy that 350 and dump money in it for about 1500 right? lol
Thank you MeWhoahIts you were helpful
