Rear Block Lift Question
I am soon about to lift my 89 F250 2wd with a 6 inch skyjacker lift. The only lift i can find for it has blocks for the back. Ive heard bad things about block lifts, but i really am not gonna do much offroading at all, its mainly for looks. My question is will it help and be more stable if i were to weld the blocks on to the springs?
No don't weld the blocks in. If that was a good idea, they'd recommend it to begin with. just torque U-Bolts down to whatever specs they give...or as tight as you can. The only time you spit out a rear block is when somebody forgot to tighten bolts down. the biggest concern is axle wrap. You floor it and the axle pivots underneath the blocks. And if you have a real issue with that, install some ladder bars to correct it. But if its just a road truck, I wouldn't worry about it too much.
6" is a huge block. I'm not sure I'd feel comfortable with that much block. Maybe do a shackle flip in the rear, and use a shorter block?
Ford Rear Shackle Flip Kit - Sky's Off-road Design
Mide rode pretty good, and that was even with a fitted add-a-leaf too
Skyjacker part #FR56S is the 6" rear spring. you need 2
Received 3,108 Likes
on
and they are much safer than blocks. i just put a set on my 88 to replace a broken main leaf. ride surprisingly well for a 6 inch lift spring.
