ROSEWOOD STAGE 1.5 OR 2?
Old 09-01-2012, 11:45 AM
smash fascism's Avatar
smash fascism
smash fascism is offline
I have already purchased my s366 turbo and t500 oil pump. I want a reliable truck, do you think the stage II's would be ok?
Old 09-01-2012, 11:57 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Ford4Life7.3 is offline
People typically go with stage 1's or 1.5's with the s366 it seems. I guess if you wanted to get a little extra power you could have the stage 2's tunes down to right where its best for you. Id say go with the 1.5's
Old 09-01-2012, 11:58 AM
Ford4Life7.3
Then again i believe there are guys eunning stage 2'a with the d66 which is more or less the same.
Old 09-01-2012, 12:38 PM
fordpride's Avatar
fordpride
fordpride is offline
Go with stageII's 180/80
Keep in mind to run the s366 you have to go with e-fuel if you using the irate mounting kit.
You'll also need a IC or get creative with a intake spyder
That set up with the right tuning will put you around 425hp
Old 09-01-2012, 12:57 PM
smash fascism
why do I have to run E fuel?
Old 09-01-2012, 04:23 PM
fordpride's Avatar
fordpride
Cause the irate kit uses the hole for the stock fuel pump as the oil return for the turbo
Old 09-01-2012, 10:29 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I'll probably go with the stage 2's like you have Mike but is it an option for the springs, head studs and push rods or a must have? If its a must have then I might just go with stage 1.5's, IDK!
Old 09-01-2012, 10:44 PM
fordpride's Avatar
fordpride
It's only a must have if you plan on running hard high RPM'S like racing and WOT runs. Just using it to tow I think you'd be fine. I just don't see you towing at 40psi of boost
Old 09-01-2012, 10:48 PM
fordpride's Avatar
fordpride
You could always do a set of 238/100 hybrids the you can have them tuned for any injector from stock or stageIII or anything in between
Old 09-01-2012, 11:56 PM
oldbird1965
hahahaha, no I can't see towing at 40psi of boost, that's for sure. Mine will melt down now at a continuous 20psi towing.
I'll be honest, I don't know enough about the different size injectors.
Old 09-02-2012, 12:08 AM
glovemeister's Avatar
glovemeister
glovemeister is offline
I'd go size two and have them detuned. You really can't go bigger on flow than what you have. But you can sure go lower.
Old 09-02-2012, 08:08 AM
smash fascism
Yeah I was considering hybrids, but seems though im already changing the HPOP I shouldnt have to worry about running out of oil should I? Is there any other plus to having hybrids besides the fact they use less oil?
f1501987
02-24-2013 11:19 PM
bruce51d
16
11-09-2008 07:40 PM
crapr6
05-19-2008 07:34 PM
Hiflyer746
08-26-2007 03:28 PM
BoostLover
10-28-2003 05:44 PM
Quick Reply: ROSEWOOD STAGE 1.5 OR 2?
