Evap Pressure Sensor
Old 02-15-2008, 04:50 PM
darascal's Avatar
darascal
darascal is offline
Is There Another Name For The Evap Pressure Sensor Please
1997 Ranger
3.0
176000
Old 02-15-2008, 05:33 PM
darascal's Avatar
darascal
darascal is offline
Heres The Real Question
I Am Having A 1443 Code That Will Not Go Away!!! I Have Changed The Purge Valve And The Sensor(thermistor) The Dpfe And The Egr Regulator Valve(?) I Have Forgotten The Name Of It I Think. At Any Rate I Don't Think Anythink Is Left To Replace. My Question Is--is It Possible That The Seal On The Tank Where The Pump And Float Go In Being Less Than Perfect Is Causing This??
Old 02-16-2008, 06:04 AM
darascal's Avatar
darascal
darascal is offline
evap canister
MAYBE someone will know if there is a way to know if the EVAP canister is bad other than a just looking for cracks and external damage any help is appreciated
Old 02-16-2008, 07:03 AM
darascal's Avatar
darascal
darascal is offline
boy do I feel stupid all, this time I have been trying to get rid of this 1443 code and this morning is the first time I think to pull the evap canister off and WOW, there is a big hole in the back of it. I am definetly not a mechanic but to me this just seems like a problem. So I guess my next step is to go to the junk yard and try to find a can. without a hole in it. I will post the result
Old 02-16-2008, 10:31 AM
darascal's Avatar
darascal
darascal is offline
Well Replacing The Evap Can. Didn't Do It. The Only Other Idea I Have Been Given Is A Blocked Hose Between The Purge Valve And The Ftp Sensor,but I Can't Find The Hose They Are Referring To. The Only Hose That Goes To The Tank WHERE THE FTP IS SUPPOSED TO BE Comes From The Evap Can. Itself. Doesn't Anyone Have Any Ideas. ALSO THE PRINTOUT FROM AUTOZONE SAYS THE EVAP PRESSURE SENSOR MAYBE FAILED. WHAT IS A EVAP PRESSURE SENSOR
Old 02-16-2008, 05:53 PM
darascal's Avatar
darascal
darascal is offline
no ideas out there
Old 02-16-2008, 06:48 PM
pawpaw's Avatar
pawpaw
pawpaw is online now
P1443 is for small or no purge flow, so check the canisters purge valve, it's actuating solenoid & the solenoids electrical connector & wiring, the output vacuum line from the canister over to the intake manafold, for obstructions, kinks, cracks, connections, ect.
Old 02-16-2008, 06:54 PM
antony25's Avatar
antony25
antony25 is offline
P1443 is caused by a faulty purge flow sensor. Three wire sensor located near the canister purge solenoid.
Old 02-17-2008, 06:45 AM
darascal's Avatar
darascal
darascal is offline
I have replaced all the vacuum lines(under the hood) and sensors and the purge valve still no joy thanks for the help
Old 02-17-2008, 07:06 AM
pawpaw's Avatar
pawpaw
OK, did you replace the canister with a new one, or one from a salvage yard????
Have you checked for a purge signal at the purge solenoids electrical connector???
If so, is the solenoid working???? Just because it's new shouldn't automatically earn it a pass, make those new parts earn that pass!!!!
Pull the canisters input vapr line that comes from the gas tank & check for vacuum at the canister connection, when you start the engine.
If none there, then pull the canisters output vacuum line that goes over to the engine & check for vacuum on the hose.
Let us know what you find.
Old 02-17-2008, 08:12 AM
darascal's Avatar
darascal
darascal is offline
1.)I used a canistor from the salvage yard $10 v/s $135
2.)I have strong vacuum from the intake hose but if there is any vacuum at the canistor where the tank line connects it is minimal
3.) I am going to have to look around to figure out how to test the purge valve connections to give an answer on that
Old 02-17-2008, 08:25 AM
pawpaw's Avatar
pawpaw
OK, good test & feedback, so you know the vacuum line to the engine is unobstructed, now you can concentrate on the evap systems electrical signal to the purge valve actuating solenoid & it's operation of the purge valve.
Did you make sure the canister you got from the salvage yard was ok & not saturated with fuel????
Old 02-17-2008, 08:30 AM
darascal's Avatar
darascal
darascal is offline
I did the best I could by squeezing it to see if I could feel the charcoal moving I also smelled it and it didn't smell to strong of fuel.
I am still looking for test procedures for the electrical side and I will post my findings
Old 02-17-2008, 09:31 AM
antony25's Avatar
antony25
antony25 is offline
Make sure your new purge flow sensor is not installed backward.
Old 02-17-2008, 09:51 AM
darascal's Avatar
darascal
darascal is offline
well in the process of checking vacuum with a hand vacuum pump I discoverd that although new it appears that some of the lines were too large and allowing a leak so new lines on I am going to take it for a test drive to see if the CEL stays off
Quick Reply: Evap Pressure Sensor
