6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
P0088
Old 08-26-2012, 09:59 PM
pyro2nite's Avatar
pyro2nite
pyro2nite is offline
P0088
Comming back from vacation, the CEL came on. P0088 fuel rail pressure to high............what do ya think??????? Yes filters changed.
<!-- / message --><!-- sig -->__________________
Old 08-27-2012, 04:54 AM
slowmans's Avatar
slowmans
slowmans is offline
Ugh oh..... Any water when you changed them?
Old 08-27-2012, 05:10 AM
senix's Avatar
senix
senix is online now
Received 1,430 Likes on 1,023 Posts
there is a flash out there that needs to be done. People were having their hpfp's changed because of the code when they were in fact ok.
You changed your filters. Was the bowl nice and clean? No rust or metal? Then I'd get the flash.
TSB 12-7-7
Old 08-27-2012, 05:20 AM
pyro2nite's Avatar
pyro2nite
No water, not rust, everything nice and clean.
Old 08-27-2012, 05:22 AM
pyro2nite's Avatar
pyro2nite
Don't know if the flash is the answer. Mines tuned, Nothing special, just the delete with +75hp.
Old 08-27-2012, 05:26 AM
senix's Avatar
senix
senix is online now
clear the code and drive on then. See if it comes back. If so then maybe get the flash.
Old 08-27-2012, 05:44 AM
pyro2nite's Avatar
pyro2nite
Already cleared the code. I'm afraid the pump will start to come apart and take out the injectors.
Old 08-27-2012, 07:29 AM
vloney's Avatar
vloney
vloney is offline
choice is yours, $3000 or $100
<TABLE border=3 cellSpacing=0 cellPadding=3 width="96%"><TBODY><TR><TD bgColor=#0000ff colSpan=2> </TD></TR><TR><TD class=VERTCENT bg*************** width="25%" align=middle>TSB
12-7-7
</TD><TD class=VERTCENT bg*************** width="65%" align=left>
  • 6.4L - LACK OF POWER - DIAGNOSTIC TROUBLE CODE (DTC) P0088
</TD></TR><TR><TD bgColor=#0000ff colSpan=2>[************]Publication Date: July 17, 2012[/COLOR]</TD></TR></TBODY></TABLE>
<TABLE border=0><TBODY><TR><TD width=230>FORD:
</TD><TD>2008-2010 F-Super Duty</TD></TR></TBODY></TABLE>
This article supersedes TSB 11-4-22 to update the Service Procedure. ISSUE:
Some F-Super Duty 250-550 vehicles equipped with a 6.4L diesel engine may exhibit a lack of power concern with an intermittent DTC P0088; at full operating temperature during moderate to heavy acceleration. A calibration update is available to resolve this concern.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Intermittent P0088 diagnostics:
  1. Check all continuous memory DTCs. Is DTC P0088 the only code present?
    1. No - this article does not apply, refer to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to diagnose this concern.
    2. Yes - continue to Step 2
  2. Reprogram the powertrain control module (PCM) to the latest calibration using IDS release 79.05 and higher. This new calibration is not included in the VCM 2012.5 DVD. Calibration files may also be obtained at Buy Motorcraft Parts Online | Official Motorcraft Auto Parts Site | FordParts.com.
flatbedfordguy
06-05-2018 08:36 AM
Gimpy
1983 - 2012 Ranger & B-Series
16
07-14-2016 12:58 PM
6t6merc
16
11-25-2012 02:38 PM
Dirt Boy
15
06-14-2005 10:03 PM
Folly5678
1999 to 2016 Super Duty
17
03-09-2003 01:13 AM
Quick Reply: P0088
