What did you do to the Bronco Today?
#2675
I recently had to replace the steering wheel shaft on my PSD. Not a cheap fix! Bearings, and shaft were toast....
#2677
#2678
By the time I get done here......I'm gonna have a NEW Bronco!!! Got the trans fluid topped off. Rear driveshaft in. Rechecked all the fluids. Started her up and went to put it her drive to check the gears and thought......"Man...the shifter has a lot of play in it." The shift shaft in the column broke! I hear it's a common problem......but I've never had one break! I see Dorman makes a kit for it.
Anybody done one???
Anybody done one???
#2680
on
I love the free Wheelin Package decal kit on the black Bronk.
As for the wheel polish stuff that is just sprayed on and rinsed off.
I get what is called Wheel Brite at Napa. Have used it for years.
And yes all acid based will eat away at the wheel. So once a year
or about after every gallon of cleaner I polish the wheels. This gives them
like a chrome shine and lasts pretty well.
#2682
I'm in upgrade mode on mine still, I've owned it almost 2 weeks now. I've gotten quotes on replacing a broken leaf spring, and upgrading exhaust to Flowmaster. Should sound awesome with the 351. I also have a squeal/squeak that only happens under power, I haven't located yet. I think it's either the CV, or U joints. Hard to diagnose, but it squeaks......and stops when I let off the throttle. It's a work in progress!
#2683
Got the shift shaft tube replaced.....wasn't too bad. Now I've got to try and find some column covers for a tilt wheel. Mine have degraded so bad it's not worth trying to fix them again. (They were held on with black electrical tape when I first got the Bronco!!)
I'll go down to the U Pull It yard Monday and see if I can find any.
If anyone knows of any for sale for a 92-96 Bronco, F150/250/350/450.....let me know! (I think they're all black.)
#2684
