1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 08-30-2014, 09:08 AM
gatorfor88's Avatar
gatorfor88
gatorfor88 is offline
Originally Posted by GruesomeJeans
I haven't done much, I bought a battery for mine so I can start trouble shooting. There was an interesting noise last time I ran the motor.
Was it a chugga chugga ping ping doodoo bebop noise or a baboomba baboomba bedinga dinga doodledump noise?
  #2312
Old 08-31-2014, 01:34 AM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Doodlebump .
Actually it sounded almost like a lifter tap. However, the oil is old and at this point probably low. My main concern at the time was getting it back in it's spot since it had been stuck in the neighbors driveway..
  #2313
Old 08-31-2014, 01:43 AM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
Figured out why my engine wouldn't start, had 2 wires turned around. Pulled the 9" form under it and am in process of installing the 10.25. That axle is a brute! and heavy too!
  #2314
Old 08-31-2014, 01:45 AM
GruesomeJeans
Coil wires? That was my issue when I first got TGM. We tried to tune it and the coil wires had been cut and re-taped by the PO. One wire broke connection and that was the end. Cost me over 150 in guessing what part broke.
  #2315
Old 08-31-2014, 03:57 PM
jasoncarpenter1's Avatar
jasoncarpenter1
jasoncarpenter1 is offline
So I broke my pass side outter shaft while in a tandem pull. Great time to install the chromoly 35 spline shafts I bought a while ago.
All good now....................
  #2316
Old 09-01-2014, 10:02 PM
FourXFord2's Avatar
FourXFord2
I got the 10.25 bolted up today and was working on new brakes when realized that I was missing a slack adjuster and the adjuster cable on other side is only half there. Also noted the park brake cables will not work. Back to the parts store.
  #2317
Old 09-03-2014, 10:16 PM
FourXFord2's Avatar
FourXFord2
Getting closer! New park brake cables installed, new wheel cyliders,new brake pads,and new drums installed. Got tired of fighting those retaining springs so I made a tool from some 5/16 rod to help install. Works sweet.
  #2318
Old 09-04-2014, 08:55 PM
GruesomeJeans
I fired up the bronco today, after about 3 months. I plan to drive it tomorrow night to work.
  #2319
Old 09-04-2014, 09:22 PM
FourXFord2's Avatar
FourXFord2
I found some tires, wadda think? 9.5 x 16 BFG Silvertowns. Tires were free, tubes cost me $80.
  #2320
Old 09-23-2014, 12:39 PM
FourXFord2's Avatar
FourXFord2
Pulled the '78 out of the weeds and. Got it running. 4tires, a lot of soldering to fix gas tank and new track arm bushings, just needs new wiper blades now.
  #2321
Old 09-23-2014, 07:28 PM
FourXFord2's Avatar
FourXFord2
Got tired of smelling the rodent urine soaked paper glovebox so I removed it, pulled the staples and laid it flat. I wanted to use aluminm sheet but all I had was stainless steel. Traced the cuts onto steel and cut with zip disk and 4" grinder. Then I marked the bends and folded it up and secured it with stainless screws. Gound off the inside pointed end of screws, then installed it and marked and predrilled the holes. Reinstalled it and the door with more stainless screws.
Next step will be to find some felt to glue to inside to eliminate anything metal thrown in there from rattling. I made it to fit tight with no extra holes so now mice won't be trying to make their home in it anymore.
  #2322
Old 09-24-2014, 01:56 AM
GruesomeJeans
Damn that's pretty awesome! I dislike the paper one just because Washington is kind of a rainy place so everything gets hit by moisture. Paper doesn't hold up well.
  #2323
Old 09-24-2014, 04:54 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
ya the oem one leaves alot to be desired
  #2324
Old 09-24-2014, 10:01 AM
jasoncarpenter1
I would love to run a set of those just once.........
What do you think of them?? What kind of mud do you play in??
  #2325
Old 09-24-2014, 04:17 PM
FourXFord2's Avatar
FourXFord2
I thought you'd like taht idea. JBG sells a plastic one too.
I haven't run the ag tread yet, still waiting on parts. My Bronco addiction forced me to start driving my '78 again. This time I have parts on hand to fix what needs fixing! Well most of them anyhow. Need to change the PS pump, I don't think it's doing it's job at all, also some steering stabilizes would be nice. It never had a coolant overflow tank so I took the one from the '94 F150 and made a simple bracket to mount it to the fender. Almost fell over backward when I discoverd the stock '78 pump connector was the same! Now I can save all the antifreeze that boils out. Tonight I need to find a reciever hitch and evict the mouse nest from the heater.
Quick Reply: What did you do to the Bronco Today?
