1978 - 1996 Big Bronco
What did you do to the Bronco Today?
Old 05-25-2013, 02:45 PM
Zip's Avatar
Zip
Zip is offline
Picked up lottery tickets for the wife yesterday before work. Gonna be millionares ya know. Turn key CLICK. Okay bad connection. Leave bronco there cause I have to go to work soon. Lunch time go to the wreckers and pick up a couple things. Positive cable is shot. After work open door and dome light comes on. Bronco faries showed up and made it good. Nope. Fiddle a bit and give up.
Go home and sleep. Remember it's 4 am at this time. Head down this morning, open door dome light comes on. Turn key. You guessed it CLICK. Leave key on and blower on. Fiddle with some wires after replacing the positive cable. Boom blower motor comes on. Turn key CLICK. Repeat 3 or 4 times. Fiddle with ground on block. Boom I think we are on to something here. Get it running and home.
Pretty bad connection. took the bolt out, things looking pretty rusty and bolt wasn't all that tight to begin with. Wire brush the poop out of it and re connect. Good to go.
  #1247
Old 05-25-2013, 07:07 PM
harleydeen98258's Avatar
harleydeen98258
harleydeen98258 is offline
Drove the '93 Bronco for the first time down the block a few times then took it out on a county rd. behind the house...not bad for a $200 truck and all I've spent so far is 2 sets of plugs and a fuel pressure regulator.
  #1248
Old 05-25-2013, 10:21 PM
FourXFord2's Avatar
FourXFord2
FourXFord2 is offline
Brakes went out on the '91 on my way home from work. Resivoir was empty so added a pint to it, stepped on the brake pedal and heard a hiss from the back of the vehichal. Had the wife step on the pedal while I was under it and found the driverside brake line was broken next to the junction. Pulling the line off was a bear because it was seized to the nuts. Center one was easy because it was broke off. Reflared the line and put it back on for now. Purchased 25 ft roll of 3/16 of NiCuFe line now to make some new lines for the 9 inch rear.
  #1249
Old 05-26-2013, 12:58 AM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
I'm glad no accidents occured while you had no brakes Greg, brakes are one of those items we forget about until they scream for help or fail...
  #1250
Old 05-26-2013, 01:14 PM
ywhic's Avatar
ywhic
ywhic is offline
2 new Monroe (rear of the front axle) LT shocks.. what a PIT(Butt) to get the old top nuts off..
Still have to do the front (of front axle) but thats another day.. (Passenger side stud broke.. hence another day for them),,
  #1251
Old 05-26-2013, 01:22 PM
Raptor13's Avatar
Raptor13
Raptor13 is offline
ywhic- Ha I'm actually thinking of getting shocks for my bronco today. Only problem is the front of axle and behind axle is confusing me. It still has the factory shocks on it :O
  #1252
Old 05-26-2013, 01:23 PM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
I used a sawzall for all 4 shocks on my 93 and 96
  #1253
Old 05-26-2013, 01:52 PM
ywhic's Avatar
ywhic
ywhic is offline
The front of front axle are longer (and not truly needed).. some people leave them off when doing the shocks..
The rear of front axle are shorter and are needed.. these are like most F150 trucks.. This for me was an 18mm socket and 18mm air socket for the bottom bolt.. the top was 14mm though rust may make the top bolt shrink to 13mm or 1/2".. (Darn rust)..
Not all Bronco's have quad-shocks up front.. only the TOW models from what I've learned..
The Monroe LT's were at the local Advance for like $25 each.. and I had a good coupon so I bought all 4 for the front..
Upon removal the passenger side had no/very little lift left in it.. the driver side though very rusty still had some life in it and came back up pretty fast (not as fast as the new one though)..
  #1254
Old 05-26-2013, 02:12 PM
Raptor13's Avatar
Raptor13
Raptor13 is offline
Sweet thanks for all that info good sir.
  #1255
Old 05-26-2013, 02:13 PM
1_ton_bronco
I recommend rock auto for cheapie shocks lol
  #1256
Old 05-26-2013, 02:55 PM
Raptor13's Avatar
Raptor13
Raptor13 is offline
Haha that's actually one of the sites i am looking at.
  #1257
Old 05-26-2013, 03:00 PM
1_ton_bronco
I bought $250 worth of stuff from there and autozone was $540 for the same stuff
  #1258
Old 05-26-2013, 03:02 PM
Raptor13's Avatar
Raptor13
Raptor13 is offline
Oh yea I know how that goes I don't ever use local stores anymore unless it is a got to have it right now item. Other than that I will always wait an extra day or two for it.
  #1259
Old 05-26-2013, 03:05 PM
1_ton_bronco
Yea I hear ya.. I even bought stuff for my f100 off there because most of it is USA made.. Or most of the parts I buy are.. Unless its 5/16 fuel hose or vacuum hose.. Ill go to autozone
  #1260
Old 05-26-2013, 03:07 PM
Raptor13's Avatar
Raptor13
Raptor13 is offline
Same here. I have the tendency of only buying products that are stamped with made in USA. Unless it is minor stuff that would be rather difficult trying to get it.
Quick Reply: What did you do to the Bronco Today?
