What did you do to the Bronco Today?
I tried and failed at replacing some fuses. I have the glass ones and the PO decided he was too cheap to buy some so he used tin foil. Of course this doesn't jive with me too well so i figured i would take a look and fix it. Turns out i don't have the correct fuse either... I did however pull the tin foil out for safety sake. once i get some more fuses that will work i can fix it. One was for the instrument cluster and the other i am not sure about. All it said was coast Lbs and it was i think 15 amp.
Ordered all of the wheel bearings and seals to rebuild 1 side of the front axle. Since I am converting it to 8 on 6 1/2 outers from a Dana 44 HD to make the front match the Dana 60 rear. I figured this would be a great time to rebuild everything. I only got 1 side cause it will probably be another few months before I got to the other side...
Yeah learning how to work on cars. Putting headers/gaskets on is the best place to start! I haven't done it yet, but i plan to use TGM today to help a friend and co-worker of mine move out of her apartment. Now that i can safely drive it, it is the only truck she knows up that can haul her bed and chair.
#29
I picked up my wheel bearings from Auto Zone then got in trouble when I got home for spending too much time in the garage. I agreed to spend time with my wife and son in the house tonight. I made dinner, gave him a bath, and put him to bed. Then I sat on the couch with my wife while she watched her TV shows and I started typing up my build thread (finally) on the laptop while sitting next to her.
Here it is.
https://www.ford-trucks.com/forums/1...big-truck.html
At least that is the start, I'll keep updating it as I have time until I get it to where I am now.
Stay safe and keep working on those Bronco's!
Here it is.
#30
Bigzirb, Already following your build,looks Good! Mine started out the color too.
Playing with the bronco today, Switched the vacuum advance from a ported vacuum on the carb to full time manifold vacuum. Found out the advance in the dizzy is bad. So that could be why it pops so much When I get on it?
Hope to find the other dizzy this weekend!
