jaydee2709
You have air in brake system.
Is the system leaking fluid. Is there moisture in the fluid.
Start at rear and bleed brakes carefully. Put a small hose on end of bleeder and into fluid container. Keep master cylinder full of fluid.
You should do this when truck is running. Seems to help me get a firmer pedal.
After you are sure There is no air in rear then go to front.
Try bleeding them again and let us know how it turns out.
Links_vette
36
01-23-2021 07:41 PM
headtube
04-21-2018 07:52 AM
Thedonk
10-18-2016 10:06 PM
