Air bubbles in glass and rough running under load? Help Please
The Flathead starts instantly and purrs.At idle there is a bit of air on top of the gas in the glass bowl.When I increase the rpm more air and it looks like boiling water.
I tightened up the hoseclamps etc and it does not boil like water anymore,but still there is a bit of air on top in the bowl.Underload it runs a bit better,but not much.
I have not replaced the gasket on top of the glass bowl. I'll do that today.
If anyone has any words of wisdom,thanks in advance.
Cheers
Cheers
Then check the output of the pump if you're still having problems. How does it run under heavy load? Or are you just concern about the bubbles?
The Flathead starts instantly and purrs. At idle there is a bit of air on top of the gas in the glass bowl.When I increase the rpm more air and it looks like boiling water.
I tightened up the hoseclamps etc and it does not boil like water anymore, but still there is a bit of air on top in the bowl. Underload it runs a bit better,but not much.
You need to give us a description of the engine operation problem. Does it stumble as you open the throttle or what? Also note the level of the fuel in the bowl in Ilya's video. If your float level is set too high that will cause problems.
kirbyf
07-30-2014 05:08 PM
