Front tank fuel pump question.
They say the front tanks in 96 model F250s are pretty good at the fuel pump not working.\Others have told me it could be just the switch on the dash not working. I need you guys feed back about how to trouble shoot getting the front tank fuel pump to work again without ripping the truck tank out to fix. Help! lol (not funny, just tired of this)
This diagram for a 1991 F-series is the same as your 1996:
Verify voltage is leaving the switch for the front tank when it is selected. The Red (R) wire supplies power to the front tank. Put your meter or test light on the wire and a ground to measure/test for voltage.
Verify voltage is leaving the switch for the front tank when it is selected. The Brown/White wire supplies power to the front tank. Put your meter or test light on the wire and a ground to measure/test for voltage.
I think that should be the red (#786) wire for the front tank.
No ????
Bob
pcurtice
09-18-2016 03:58 PM
dhuddleson
10-30-2015 06:29 PM
1981FordF250 Granny
09-19-2009 01:54 PM
redmille
02-22-2009 07:27 PM
