Ford 9" vs Sterling 10.25
Hey guys. Iv always seen on TV and elsewhere that when you make big power, you upgrade to the Ford 9 inch. I have yet to see the Ford 9" discussed in our 87-96 forum. Why is that? Is the 10.25 just as strong? Or has no one made big enough power in our trucks to need one (which I doubt). Or is the swap too much of a PITA?
I'll throw in some numbers to back up what others have said. According to the '89 light duty spec book, both the 8.8" and 9" axles are rated at 3850 lbs (why the 9" is even in there, considering it had been out of production for at least two years, is beyond me), where the full-float Sterling is rated at 6000#. Even the semi-float Sterling can handle 5300 lbs.
It's strictly my opinion, but I think the 9" can handle at least as much power as the 10¼" axle in stock configuration. I'm all for putting a 9" axle in a pre-'92 half-ton for two reasons...real drivers don't need RABS, and because I've never heard of anyone losing an axle in a 9", where I've SEEN c-clip axles break at the strip.
Moral of the story...if you're installing an axle for power, put in a 9". If you're installing an axle for towing or hauling, get the Sterling.
Pat
Pat
You can't even try to compair the two axles.
The 9 is good for half tons as mentioned, with tires less than 35s. And even with 35s, upgraded shafts are prob on the "to do list"
The 10.25, is beef. I have ran 44s on a stock 10.25(just a gear swap) and twisted a a LS shaft after a few years of extreme abuse.
If you have a hot rod, or half ton pickup the 9 is where its at. If you have anything bigger, the 10.25 is the answer.
on
There are HD axles and c-clip eliminators available for the 8.8 so overall it's as capable as the 9". And make no mistake if you source a 9" from an old 80's truck it won't have bullet proof axles in it that will take the abuse of a big torquey motor.. you got to get one from an old '70's car that had a big block under the hood to get that. The big issue with using a 9" in these trucks has to do with the trans, if your truck has one of the electronic auto transmissions then you need an axle with a VSS so the 9" is out of contention.
sixseven
21
08-01-2015 10:57 AM
steve33444
19
01-08-2015 08:40 PM
jmteam6
07-09-2006 12:13 PM
yellow tonka truck
04-09-2004 12:31 AM
