Fuel Hydrolocked - HELP
For starters the truck is an 87 f150 302 auto 4x4. I was driving a few days ago and The truck started running rough, mainly at idle but would kinda sputtered when letting off the gas. Seemed to run fine when getting on it. I got home to try and diagnose the problem had it idling in the driveway and it would bog down to about 400 rpm and then back up to 850ish consecutively and after messing with the throttle it stalled. I cranked it over for about 5 seconds and it locked. Pulled al the plugs out and piston on driver side closest to cab was dumping fuel out when cranking it over, put all plugs back in and fuel relay back in it cranked for 5-7 seconds and locked again, obviously the objectors is leaking but it seems like a rediculous amount of fuel for only cranking it over a few seconds.
Unplug the injector on the cylinder that's leakin fuel. Then crank it. That will tell you if the PLC output is stuck on or shorted to ground (injectors are sink logic) somewhere, or if the injector is stuck open mechanically.
That seems like an awful lot of fuel though. I don't think it would be a fuel pressure issue cause then ALL the cylinders would be doing it.
I am sure you already did this, but please make sure you are unplugging the power supply to the coil when you are cranking. If not that will make a nice toasty fire real quick.
Just unplug the vacuum hose from the regulator, and you will know if it the regulator, or the injector. Fuel squirts or runs out when you cycle the key. Then it's bad
97F250LD4X
06-14-2010 11:49 PM
nightskyisme
25
04-22-2007 07:37 AM
