Good Shops in the SF Bay Area
Hi,
I originally posted the following in the Nor-Cal chapter forum and got no response so I thought I'd try here.
I need to have some work done to my '53 Ford to get it road worthy once again. Since I have limited time and skills, I need to find a good shop in the SF Bay Area that will be willing to do the following type of work:
Install a Mid-Fifty Front-Down and Forward Spring Kit
Install a Mid-Fifty Complete Disc Brake Conversion Kit
Rebuild steering box and/or front end
Install sway bars
Install replacement side and wing window glass
Install wiring harness
Any references or suggestions are gratefully appreciated!
Thanks,
BDL
Install sway bars
Thanks,
BDL
You should post this question over on the HAMB. You'll get a better response there.
You can also try these guys in San Jose, http://gambinokustoms.com/. I don't know how much they charge. What you want done won't be cheap since it requires a lot labor hours.
mad103
19
02-03-2016 10:06 AM
LittleRadio
05-23-2011 07:29 AM
dmalmgre
01-12-2008 02:34 PM
