49 Ford F1
Old 01-04-2015, 11:04 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
I was searching the net and found that bobj49f2 was trying something similar to what i want to do with a remote reservoir on his Buick. Did you ever finish that project bob?
  #362
Old 01-18-2015, 10:01 PM
eanquiel's Avatar
eanquiel
eanquiel is offline
Flathead 8BA engine races at full throttle when started
Hello, I recently restored a 49 F1 flathead 8BA. I installed a new wire harness and made sure all wiring was correct with positive ground now for some reason when I start the engine is races at full throttle when started without pressing on the gas. Any idea why now when it starts it would race at full speed without pressing the gas? I have taken the carb cover off and cleaned the jets again but it didn't help. Could this be a wiring issue or is it an issue with some internal component in the carb? Thanks for your help!
  #363
Old 01-18-2015, 10:10 PM
Moe Craig's Avatar
Moe Craig
Moe Craig is offline
Only could be a carb issue...
  #364
Old 01-18-2015, 10:23 PM
Gicknordon's Avatar
Gicknordon
Sounds like carb to me too. I would suggest starting you own thread on it though. You will get better help that way.
  #365
Old 02-01-2015, 04:36 PM
Gicknordon's Avatar
Gicknordon
So I think I straightened out my radiator clearance issue. I took an extra radiator saddle that I had and cut the mounting brackets and cross bar off and tacked it to my good radiator saddle. This moved the radiator forward so that now I have about 3.5 inches of clearance between the water pump and radiator. This ended up being a pretty clean set up since it uses only stock parts. Now i just need to find a v8 hood air deflector because my 6 cylinder one comes down right on top of the radiator.
  #366
Old 02-01-2015, 07:26 PM
arctic y block's Avatar
arctic y block
arctic y block is offline
Way to go. Awesome if it works for ya.
  #367
Old 02-08-2015, 04:13 PM
Gicknordon's Avatar
Gicknordon
Thought I would mount the front sheet metal and running boards to see what my ride height will look like. I'm pretty happy with it i think. My $5 lower fenders are gonna need some reshaping, but i can't complain for $5.
  #368
Old 02-08-2015, 06:11 PM
Moe Craig's Avatar
Moe Craig
Looking good... Looks like your getting close!
  #369
Old 02-08-2015, 06:31 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Nick,
The front clip looks good - nice height. It looks like the nose took one for the team.
Ben in Austin
1950 F1
  #370
Old 02-08-2015, 07:00 PM
Gicknordon's Avatar
Gicknordon
Thanks guys. I bought that hood mainly for the trim and latch mechanism. I might swap that stuff onto the hood that came on the truck so I don't have to deal with those dents.
  #371
Old 02-10-2015, 05:38 PM
NFLD FLARESIDE's Avatar
NFLD FLARESIDE
NFLD FLARESIDE is offline
Looking good
  #372
Old 03-07-2015, 02:26 PM
Gicknordon's Avatar
Gicknordon
So, finally back at it! Today I started getting the front fenders fixed. The drivers side upper fender doesnt need any rust work, as i bought one already fixed a few months ago for pretty cheap. The lower fenders that i bought aren't as nice as i originally thought. The drivers side was hit, apparently many years ago. I found a big patch of lead covering up a big gash in it. That wouldn't have been to bad, but that damage also made the panel pretty misshapen. I decided just to finish the lower fender i started a few years ago. I am using the doubler from the one i bought, since that is solid and the fender i bought at least gives me a template to make a patch panel, since my original fender was pretty much gone in that spot. The new fender would have needed metal replaced in the same spot anyway.
This is the new fender.
The lead
And the start of fixing the old fender.
My dad also helped me set up the tig for his big miller welder. Learned a lot in just the bit of time i spent on it. Welds don't look too bad for about half hours worth of practice!
  #373
Old 03-09-2015, 05:34 PM
Gicknordon's Avatar
Gicknordon
Continued work on the fender this afternoon. I tried the tig for these patches, and i'll tell you, i should have tried it a long time ago. The tacks don't require very much filler wire at all, so they will not need very much grinding at all! Still have to practice keeping the tungsten out of the puddle though.
  #374
Old 03-10-2015, 11:23 AM
Gicknordon's Avatar
Gicknordon
Pretty much got the lower fender finished up. Really like using the tig for sheetmetal work now.
  #375
Old 03-11-2015, 02:48 PM
Gicknordon's Avatar
Gicknordon
Started on the other lower fender today. The bottom looked good from the outside, but after i took the doubler out i decided that the area was too thin to not fix it now.
Quick Reply: 49 Ford F1
