Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 08-13-2012, 08:21 AM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
Garage is empty, add now
fordf350camper is starting off with a positive reputation.
Ford f350 1957 LHD to RHD possible or not
Hi with living in the UK and we drive on the right hand side.Did ford make a RHD ford 1957 f350.I would like to swap from left hand drive to right as the truck iam buying is quite large so overtaking can be a problem as it can be hard to see.So is there a right had drive box and what else would i need.It has a floor change gears,Would i need a different gear box.It has a straight six engine.Thanks
  #2 (permalink)
Old 08-14-2012, 12:00 PM
3414 3414 is offline
1960 Ford F-600
My Garage
3414 is gaining momentum as a positive member of FTE.
You might want to try to contact someone familiar with Ford trucks sold in Australia. I have seen brochures for sale that showed Ford mediums that had the looks of the 57 to 60s. Technically, switching over the steering box should not cause an interference with the Six. Steering linkage parts (primarily the arm from the spindle to the drag link) could be fabricated if need be. And moving the battery to mount the clutch and brake master cylinders should not be a big deal either. The biggest problem that I see is the dash. If you could not get a complete unit, it would take a fair bit of cutting, welding, and fabricating to properly support the steering column and pedal assembly.
  #3 (permalink)
Old 08-14-2012, 12:08 PM
1960 Ford F-600
My Garage
Look at this -
1960 Ford F500 3.5 Ton Truck Brochure Australia | eBay
  #4 (permalink)
Old 08-14-2012, 08:41 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I'm still trying to imagine what you'd be 'overtaking' with an F350 with a 223 cu in six....... And no, I'm not being a snob... I went to a 210 cu in straight six in my F350, and I have yet to overtake anyone. Hoping to come across a volkswagen bus on a hill at some point Good luck on your search. I have been tempted over the years to buy a rhd vehicle to use here in the states ( toyota landcruiser diesel etc), but being on that side just seems wrong so I feel your pain!
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 08-15-2012, 06:23 AM
1960 Ford F-600
My Garage
Years ago I did some "overtaking" with a worn out 58 F500 with a 223 six (often with a load), although it was usually just the guy delivering the mail. That thing was geared and tired so low that flat out on a level road 45 mph with the engine screaming was about all you could do.
  #6 (permalink)
Old 08-15-2012, 06:30 AM
1960 Ford F-600
My Garage
To the original poster - I did a bit of looking around on the internet late yesterday and found an ad from an Austrailian salvage yard parting out some 61 to 66 F Series trucks. Sorry I do not have a link for you now, but that computer is about 20 miles away right now. But somewhere over there might be the parts you will need. Maybe even cross matching part numbers from US and Australian parts list for things such as steering box, pitman arm,drag link and such might show what can be interchanged right to left.
  #7 (permalink)
Old 08-16-2012, 03:45 AM
Hi thanks for the replys.Its not just the over taking its when you want to pull out of a street you have to pull out and go on the other side of the road.And with it being LHD when you are at the back of someone you can not see on the right side ahead.Thanks hope you understand what i am trying to say.
  #8 (permalink)
Old 08-16-2012, 04:48 AM
1960 Ford F-600
My Garage
Sorry that I could not be of more help. Having the steering wheel on the proper side does make life a bit easier.
  #9 (permalink)
Old 08-27-2012, 01:33 PM
I am now going to leave this left hand drive.I went out in it and as long as i have big mirrors i am good.I just need a brake master cylinder now any ideas were i can buy one thanks
  #10 (permalink)
Old 08-27-2012, 02:13 PM
willowbilly3 willowbilly3 is offline
willowbilly3 is gaining momentum as a positive member of FTE.
Ford made most of their cars from the 30s and 40s in RHD, lots of them show up in the USA from Argentina. I'm betting they continued to fill tha market need into the 50s too but don't have any actual knowledge.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
