60 F100 Dash ?
Old 08-12-2012, 10:15 PM
KAMARAL007's Avatar
KAMARAL007
KAMARAL007 is offline
60 F100 Dash ?
I started restoring the inside of the cab of my 60. This might be a dumb question, but how the heck do you take off the control ***** on the dash? I figured they just twisted on or off but I can't seem to figure it out.
Old 08-12-2012, 11:35 PM
F250racer's Avatar
F250racer
F250racer is offline
there should be a little set screw you need to take out. For the headlight switch I think you push a tiny button on the bottom on the switch and the whole rod/**** comes out.
Old 08-13-2012, 04:19 AM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
It depends on the switch/cable..
headlight switch: pull switch to on position then from backside of dash theres a small button thats easily felt...press it down fully then tug on the shaft and it will come straight out...
Vent cables...the ***** arent removable from the cable...theres a nut on the backside of each...loosen that and pull the cable forward away from the dash for masking if you are painting.
wiper switch...theres a set screw(allen head)...loosen it and the **** slides off the shaft..
The others are straight forward(cig. lighter and glove box door)
- cs65
51f1truck
09-13-2009 10:06 AM
v8xploder
1966 - 1977 Early Broncos
03-04-2007 11:00 PM
wesh
11-11-2006 12:07 AM
trakman
12-12-2004 05:34 PM
FARM69
Electrical Systems/Wiring
07-17-2004 03:08 PM
Quick Reply: 60 F100 Dash ?
