Bought my son a '96 f150 . It has the a 302 with 132000the on it. What weight oil would be best to use on it. I plan on using synthetic just not sure what weight.
If the previous owner want running synthetic I would not use it. Stick to a quality 10w/30 if you are in a more norhterly climate(Yankee) or a 10w/40 if southerly(REBEL) when it is warm and 10w/30 when it is cooler out.
Won't hurt a thing except your pocket book to run synthetic in your engine if that's what you want to do. I have switched every vehicle I have owned in the last 10 years to synthetic regardless of miles without a problem. I use 10/30 year round.
The only reason I say not to use synthetic if you don't know what was run in it before is that I have seen more than once where you run synthetic in a high mileage motor and suddenly small leaks and seeps start to appear.
