04 Fog install Question; New bumper, lights, harness; pics pics pics
Old 04-28-2011, 11:45 PM
DallasSuperCrew's Avatar
DallasSuperCrew
DallasSuperCrew is offline
Ordered the new fogs for 04, new bumper with fog holes, and a harness.
old look:
Is there a specific DIY to convert my XLT bumper to the one with fogs?
I know I need a switch also.
Thanks.
Old 04-29-2011, 08:54 PM
Fox Fader's Avatar
Fox Fader
Fox Fader is offline
I would use a totally separate switch so I could have total control and save money.
Old 04-30-2011, 05:21 PM
dgndngrngr84's Avatar
dgndngrngr84
dgndngrngr84 is offline
I agree with fox, the oem headlight switch with the pull out for fogs is pretty expensive. This should help:
1 W505424-S301 Hood release retaining bolt
2 16B975 Hood release assembly
3 W505424-S301 Front bumper cover-to-front bumper bolts (3 required)
4 — Hood over-slam bumper retaining bolts (2 required)
5 — Hood over-slam bumpers (2 required)
6 — Air dam pin-type retainers (3 required)
7 180101-12A581 Fog light electrical connectors (if equipped)
8 N804525-S427 Frame mounting bracket-to-front bumper nuts (4 required)
9 W706599-S427 Front bumper
Remove the hood release retaining bolt.
Position aside the hood release assembly.
Disconnect the hood release cable routing retainer.
Remove the 3 front bumper cover-to-front bumper bolts.
Remove the hood-over slam bumper bolts.
Remove the hood-over slam bumpers.
Remove the 3 air dam pin-type retainers.
If equipped, disconnect the fog lamp electrical connectors.
Remove the 4 bumper mounting bracket-to-front bumper nuts.
To install, tighten to 115 Nm (85 lb-ft).
Remove the front bumper.
To install, reverse the removal procedure.
Transfer components as necessary
Old 05-02-2011, 11:36 AM
indebt's Avatar
indebt
indebt is offline
I want to this also, Dallas how much for parts you got so far? Once you start the transfer take some pics and post em up please.
Old 05-06-2011, 04:58 PM
DallasSuperCrew
Thanks guys, I'll try to post some pics.
Old 01-21-2012, 12:03 AM
DallasSuperCrew
Finally, the pics:
Old 01-21-2012, 08:02 AM
danorules's Avatar
danorules
danorules is offline
That mod took forever, lol
Looks good, I was thinking of doing the same thing. I will go with the round fogs
Old 01-22-2012, 05:45 PM
DallasSuperCrew
For yours, (06-08) round fogs should be doable no problem since that was part of the (refresh) in 06.
Old 01-22-2012, 06:19 PM
Coskid's Avatar
Coskid
Coskid is offline
I think my cab lights took a few months longer.
Old 01-22-2012, 06:49 PM
danorules's Avatar
danorules
I'm just a big kid, if I get something new I have too use/install right away. The led lights I put above the license plate got installed in the dark, with a light rain. Just because I couldn't wait until the next day
Old 01-22-2012, 10:48 PM
DallasSuperCrew
Old 01-22-2012, 11:28 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Looks good!
You should do a write up for the forum!
Stewart
Old 08-10-2012, 11:00 AM
DallasSuperCrew
Sorry, I had the local indy install them so no install pic.s
BTW, the bumper cost $100, fog lights and harness were $125 and they hooked them up to the parking lights.
frank5079
13
11-03-2015 06:24 PM
bigwin56f100
07-19-2015 06:13 PM
2many56s
06-12-2015 06:44 PM
bigwin56f100
03-25-2015 10:16 AM
Relixx
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
05-24-2010 07:07 PM
Quick Reply: 04 Fog install Question; New bumper, lights, harness; pics pics pics
