No start OBS I live in Fort Worth and It's dead in Killeen
So lets just say a great weekend with my girlfriend and her boys celebrating her moms birthday ended badly when well my truck wouldn't start. No smoke cranks and cranks. Fuses all good. Seems to have fuel pressure didn't shoot out like it should but was there. So surfing through the forum. I learned a few things.
One apperantley the search option will not search the word no as in no start. But I also found this 97-15A 7.3L DI Turbo Workshop Manual nice little manual.
I do have an IPR rebuild kit sitting in the console and would be happy as a pig in **** if this was found to be the issue.
However I do believe that I may have injector issues so I need to perform buzz test.
So I'm headed down this coming weekend with tools and a multimeter. However I need some sort of scanner. Everyone I call doesn't rent them so my question is this which ones are the most reasonably priced and will allow me to perform all the test I need to? and if you Live in Killeen and have nothing better to do I would certainly appreciate any help and would provide the beer
WTS Light?
CEL Illuminated?
How old is the oil?
Did it smoke when cranking and battery's ?
bring a extra CPS, battery cables, allen head for verifying oil in the HPOP, cause excessive cranking may bring the level down.
thats off the top of my small brain...see avatar....others will chime in...
CEL Illuminated?
How old is the oil?
WTS Light?
CEL Illuminated?
How old is the oil?
...darn slow computer or internet connection....seeing double vision
CEL Illuminated?
How old is the oil?
WTS Light?
CEL Illuminated?
How old is the oil?
CEL Illuminated?
How old is the oil?
No
Oil is maybe 3weeks old
Did at first then nothing. Batteries are both good and cranked like champs. I have new cables 3ot cables so I know that's not an issue
Read about the CPS but I believe and I am almost positive I had tach signal when cranking but I will definitely keep that in mind and I will be sure to check HPOP oil level
Is your fuel heater plugged in? If so, check the #22 maxi fuse in the under hood fuse box. It's a 20 amp fuse and along with the fuel heater it also protects the PCM and GPR. It's fairly common for the heater to short out and pop the fuse and cause a no start. If the heater is still plugged in and the fuse is blown you should unplug the heater from the side of the fuel bowl before you replace the fuse.
I will keep that in mind as well as far as the CPS.
What scanner do you use?
YOu want me To WAG my what?? I don't know if my girl would approve of such WAGGING. but seriously WAG stands for what?
