Where your Facet pump is located?
Hi guys, been away for a while...
Wanted to replace the original lift pump on my F-350 and purchased Facet 40222 pump. Now been wondering where would be a good place for it so would like to hear from those who has one installed. Pictures would be great.
Thanks and Happy 4th of July to all!
Received 3,118 Likes
on
The following users liked this post:
I’ve got mine mounted on the AC accumulator, right beside the fuel filter. If I could do it again I’d put it on the frame rail some where. I don’t think there is a good spot, but the benefits of Efuel far out weigh it taking up space.
Mine has wingnuts and longer hose, so if I wanted to I can quickly unmount it and set it out of the way without disconnecting any hoses or electrical.
I always thought a cross-mount toolbox would be a good place to mount a Facet fuel pump, auxiliary fuel filter, or even a coolant filter. I guess you'd have to drill holes in the bed though. I don't know if it'd be better to go from the front or bottom of the bed?
I should buy a Facet pump for my Bullnose. The mechanical fuel pump already failed on me, twice (once it pumped diesel into the crankcase).
rodymartin
02-23-2014 10:42 PM
