Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F600 VIN decode?
Old 08-02-2012, 10:55 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
F600 VIN decode?
Hey all, I have an old '68 F 600 truck and was curious about it's origins. It was a county weed spray truck since new.....truck is in very good shape for it's age.
Vin- F60BRC44721
wb-174
color-j
model-F602
body-4381
then under both trans and axle-(2) and F8B?
Mostly want to know if the 5 speed is OD or direct......
Oddly, this truck has a 300 six in it.
Thanks!
Old 08-03-2012, 08:01 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by tinman52
I have an old '68 F600 truck and was curious about its origins. It was a county weed spray truck since new.....truck is in very good shape for its age.
VIN: F60BRC44721 // W.B. 174 / Color: J / Model: F602 / Body: 4381 / Trans: 2 / Axle: F8B / GVW(R): 20000 / DSO code omitted.
This truck has the optional 300 six in it.
F60 = F600 (gas).
B = 300 1V I-6 / 240 1V I-6 was standard equipment. All four FT V8's were also optional.
R = San Jose CA Assembly Plant.
C44721 = 1968, assembled June 1968.
174" Wheelbase.
J = Rangoon Red.
F602 = F600 (gas), 20,000 lbs. GVWR
4381: 43 = Charcoal Black Crush Vinyl & Charcoal Black Leeds Pattern Woven Plastic // 81 = 81A Standard Cab.
2 = Clark model 282-V 5 Speed Direct.
F8B:
F8 = Eaton Model 13802 2 Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Rear Axle Capacity.
B = Ford (optional) 5,500 lb. Capacity Front Axle. 5,000 lb. capacity front axle was standard equipment.
20,000 lbs. Gross Vehicle Weight Rating.
DSO code omitted: 2 numbers = Decodes to the specific Ford District Sales Office the dealer ordered the truck from. If 6 numbers, the last 4 denote a Domestic Special Order.
You can get a copy of the original build sheet (and a lotta other stuff) from martiauto.com for a fee. Known in the hobby as a Marti Report.
Kevin Marti, a Mustang "nut" in Phoenix AZ has ALL the original 1967/79 FoMoCo records. Got them in the late 1980's when he found out FoMoCo was planning to THROW THEM AWAY!
Old 08-03-2012, 08:56 AM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Bill, thanks so much for the info!
Hard to believe that the 240 was the standard engine....
Old 08-03-2012, 12:06 PM
NumberDummy
240 I-6 standard equipment: 1965/74: F100/600, C500/600, P350/500 / 1965/71 Galaxie/LTD.
Old 12-17-2018, 10:24 AM
Nwcascades's Avatar
Nwcascades
Nwcascades is offline
I have been looking for a way to figure out my vin and information. Is there anyway you can help me? I'm sure you get tired of people asking. Thanks for your time!!!!
F6OCRC63066
Old 12-17-2018, 11:01 AM
NumberDummy
Originally Posted by Nwcascades
F60 = F600.
C = 330 2V Medium Duty FT engine.
C63066 = 1968.
174" Wheelbase.
7 = Dark Blue.
F602 = F600 .. 20,000 lbs. GVWR
4C81: 4C = Black all Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F7C:
F7 = Eaton model 13802 Two Speed Rear Axle / 5.83/8.17 / 15,000 lbs. Rear Axle Capacity.
C = Ford-Rockwell/Timken 6,000 lbs. Capacity Front Axle.
164 net HP @ 3,800 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Old 12-17-2018, 11:19 AM
Nwcascades's Avatar
Nwcascades
Thanks! I have been looking all day! So what is the F7C?
I was hoping to find a replacement wheel to get rid of the split rim. Do you know of any?
Thanks! Steve
Old 12-17-2018, 11:31 AM
NumberDummy
No.
F7C is the AXLE code, that I decoded. Look below F7C
Old 12-17-2018, 11:38 AM
Nwcascades's Avatar
Nwcascades
OK I see that now. I didn't understand it at first. Thank you!
Steve
Old 12-17-2018, 01:03 PM
NumberDummy
No.
I don't have any experience with 500 and larger series truck wheels.
There's an FTE member that is the expert on wheels. He will be able to tell you what wheel will be correct.
His FTE user name is truckdog62563. Type a new thread inre to wheels in the LARGE TRUCK forum.
Old 12-18-2018, 07:45 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is offline
If has spoke style hubs its easy conversion to 22.5 s. Just change rims and put tires on.
Old 12-18-2018, 10:43 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,596 Likes on 1,301 Posts
Steve
As mentioned in the above post, do you have a spoke style wheel, or a dish with holes?
First up here, Dayton or Budd:
Wheel types: Dayton and Budd. Pros, cons and other info - School Bus Conversion Resources
Old 12-18-2018, 10:44 PM
85e150's Avatar
85e150
Also, scroll down here to the wheel discussion with links:
https://www.ford-trucks.com/forums/1...f-n-600-a.html
Br4xton
09-11-2018 12:46 PM
TaylorDiabetoSwifty
Large Truck
03-20-2017 12:51 PM
MarkB65
Large Truck
08-11-2016 09:44 AM
Jdhacker
06-02-2013 06:18 AM
Shorty 66
03-10-2009 11:33 AM
Quick Reply: F600 VIN decode?
