gearing help
gearing help
Hello, i am looking for some help with selecting a new gear ratio. I have a95 f150, 4x4 302. The truck currently has 285 tires and i really doubt i would ever go bigger. The truck is a auto and sometimes it seems its real slow to get going from a dead stop. I assume this is sure to the larger tires and not a tranny problem. I have been told this is fixed by changing the gear ratio. I have no idea of what size, what you lose, what you gain or what to expect rpm and millage wise . any help is much appreciated
I'm sorry i don't know the current gearing, how do i find out, most of my driving is highway/around town.i really don't drive it much at all really. I live a mile from work and i have abother truck i use so i can baby my toy. Its was bought mostly for fun and going to the hunting club, about forty miles away mostly straight highway. Only towing i do is a four Wheeler, small john boat and maybe a trailer of yard trash from time to time
Well way to find out is sometimes theres a tag on the diff cover, most of the times there isn't. So at that point you will have to count the gears inside your rear diff. I would assume you have a 3.73 or 4.11 from the factory. to get better off the line you would want to go up in gears. Say you had a 3.73 or 3.55 than you would want a 4.11. Now for highway driving you want a lower gear say a 3.55 or 3.73 if you have 4.11s. Lower gears will drop your rpms on the highway, higher gears will increase the engine rpms.
Clear as mud right.
Clear as mud right.
Look on your door jamb sticker for the axle code, you then should be able to find a code chart that will tell you what it is, that is if you want to verify what the rear diff tag says. There are probably several charts floating around on here.
To calculate for the correct gear ratio for bigger tires the formula is simple. Take the larger size tire diameter and divide it by the old tire size diameter. For example, if you had 30" tires stock, and lifted it and put 35" tires on it.
Then (35/30) = 1.166667
Take this number and multiply it by what your stock gear ratio was, so if you had 3.55 gears stock
Then (1.166667*3.55)= 4.14
So, you would want to have 4.10s or 4.11s, whatever is available, to get back to how it was before.
For you, I am not sure that the 285s you are running or will run are big enough of a difference to even warrant a gear ratio change, it is expensive to regear two axles. I may be wrong though, if the truck originally had some really small 235s on it or something, than a 285, depending on the aspect ratio could be a pretty big jump in diameter.
You have 3.55 gears.
LOWER gears are HIGHER #s, as in 4.10s, 4.56s.
HIGHER gears are LOWER #s as in 3.08s, 2.73s
With a 285 upgrade from the stock, a 4.10 would get you close to stock overall gear ratio. If you want a little bit more get up and go, put 4.56s. It will make your highway rpms a bit higher, but not too bad with a overdrive.
OnlineConversion.com - Tire Size Conversion
This will help you for the tire size and then do the math thats stated above
