2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Remove Gear Selector Wood Trim
Old 07-26-2012, 12:39 PM
skytower31's Avatar
skytower31
skytower31 is offline
Ive been thinking about replacing the two fake wood pieces on the gear selector with the leather pieces from the Navigator. They look very similar.
Has anyone removed these before? Do they just pull off or is there a hidden screw I'm not seeing?
Thanks!
Old 07-26-2012, 06:05 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
They just pry off. According to the shop manual you start at the bottom FRONT only and slowly work to the top front. Also keep in mind once these pieces are removed they don't go back on.
The ones from the newer 2011 & up Expeditions are leather too so either one should fit.
Matt
Old 07-26-2012, 06:35 PM
skytower31's Avatar
skytower31
Matt
So they aren't held on by typical clips like the other console pieces?
Old 07-26-2012, 06:37 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Not according to the shop manual.
Old 07-26-2012, 06:38 PM
skytower31's Avatar
skytower31
Interesting. I wonder how they are held on?
Old 07-26-2012, 06:40 PM
RI-Matt's Avatar
RI-Matt
RI-Matt is offline
Probably small clips that break off when you remove the pieces.
Matt
Old 07-26-2012, 06:41 PM
skytower31's Avatar
skytower31
Thanks for the info. I'll report on my findings.
hwybee22
02-04-2018 11:59 AM
norfolknova
2009 - 2014 F150
06-24-2015 09:52 PM
Anafiel
30
02-16-2011 02:18 PM
JRon
08-19-2010 08:07 PM
alvald83
07-13-2010 12:48 AM
Quick Reply: Remove Gear Selector Wood Trim
