First thread...7.3L powerstroke injection stiction
Hey Everyone,
Would like some feed back on Hot Shots Secret at the following site. Hot Shot's Secret Diesel Oil Additive. Curious about anyone here having or seeing it work succesfully. Just placed an order for it and diesel extreme fuel cleaner. Diesel Extreme. Let me know if anyone has anything good yo say about either product.
My powerstroke has at least two injectors throwing trouble codes and the motor is at about half power now. Gonna give this product a shot to see if it works before I drop $3000 into the new injectors. Any comments or issues with this stuff to watch for?
Which injectors are throwing codes. If it is 3 and 8 after a CCT then that is most likely do to the CPS installed during the CPS recall. There could be other reasons for the power loss.
Is there a good engine flush treatment out there? Planning on flushing , topping off with Rotella T-6, and putting a good filter on. Was looking at K&N oil filter if that's a good way to go let me know. I also plan to swap out the water/fuel filter. A lot of maintenance need to get the beast back to normal. Really hoping to avoid swapping out 8 injectors but we shall see. Let me know the best oil and fuel filters to go with so I can Get R Dun.
I ran Hot Shot Secret for the first time Winter 2008 with some very good results. My injectors (at the time) were stock, had well over 200k, and were starting to show their age. Winter 2007, truck had a problem where an injector would suddenly start missing and the motor would pour out white/blue smoke. (motor was up to temp)
It happened again Winter 2008 and I ordered some Hot Shot Secret as a result. After the truck warmed up after the oil change with hot shot, the truck ran noticably quieter. It just so happened that I had to make a last minute drive to Dallas (4 hour drive) which gave HSS plenty of time to do whatever it had to do. After a total of 8 hours on the road (Dallas and back in one night) my truck was ran noticably better and also averaged 19.4 mpg on winter fuel. The problem I had with an injector sticking and causing blue smoke also went away and never came back.
Since then, I always take advantage of the Spring sale on HSS (2 bottles of HSS and 2 bottles of the fuel additive). I run one treatment late fall, early winter and generally have no problems.
-Drain the oil
-Change the filter
-Add good, clean oil and be on your way
As far as an air filter, The 6637 filter flows the best and is a great option for the 7.3. It's available in both paper and washable and really helps the 7.3 breathe all the air it wants.
Riffraff Diesel: AFE "Big Boost" BHAF Washable Filter
If you have the time, bread, and patience to do it, you could swap all injectors as a preventative maintenance item and do the 50 cent mod since you're already below the valve covers.
Riffraff Diesel: Stock Rebuilt Injectors
You'll spend just under $1000 for the injectors (plus the core charge), unless you go with Stage 1 injectors like I did.
A simple way to find out which injector(s) are bad is to:
-Pull both valve covers
-Start the motor and look at the top of the injector closest to the motor. You should see the injector spitting oil, if it's not, it's a bad injector.
-Another sure fire way to check is to have the motor running and unplug and re-plug the connector on the injector. If the sound of the motor doesn't change with you unplugging and replugging and injector, you've found your suspect injector.
Diesel Extreme actually saved the injectors on my 6.0 after using an additive I can't mention here, for a long period of time. My mileage tanked, starts were getting rougher, performance was suffering, and I was almost sure I'd have to replace all 8 injectors. Living Large suggested I try an additive before going that route so I did. Power Service Diesel Kleen, Stanadyne Blue Label, or Stanadyne Brown label didn't save it. The only thing that saved my injectors was Diesel Extreme. I ended up having to replace my #2 injector as it was too far gone, but the other 7 survived.
I also used Diesel Extreme along with the Stiction Eliminator on my journey to and from Dallas back in 2008.
InnovativeAV
06-24-2020 02:37 PM
