Master Cylinder Question
I have a 91 f350 4x4, I've done a dually conversion using a non-rabs rear axle. i eliminated the rabs valve, and installed an adjustable proportioning valve to the rear brakes. Before the conversion the brakes worked fine. after the pedal is firm at first then goes down slowly like the master cylinder is bypassing internally. I've thoroughly bled the system. My question is are there differences between rabs and non-rabs master cylinders. You guys have always come through in the past with my other projects. i hope some can help. Thanks!
MARC
MARC
mudrunner4ever
04-05-2013 06:35 PM
crazy96863
18
05-07-2012 11:55 PM
murrhee
03-21-2009 01:32 PM
tonpartain
06-06-2006 10:06 PM
