Blue smoke -- Help
Blue smoke -- Help
So I purchased the '06 6.0L King Ranch a couple months ago. Put 3,500 miles on it and it has run great. Watching deltas on the EOT vs. WT because the WT runs a bit high (190-192) with EOT of 202-05.
Last week, truck started to have a little puff of blue smoke when accelerating from a stoplight. In 3 days time, that "puff" become more and more pronounced. Still doesn't smoke on starting it up, either hot or cold, and doesn't smoke if I'm driving and then stomp on accelerator. Only does it after sitting at a light or stop sign.
Help with diagnostics or is there a definite problem?
Thanks!
Thanks!
Thanks!
Thanks!
Yes, EOT/WT temps are after getting to operating temps and mix driving of highway/in city. EOT did get hotter than that though after driving >80mph for 6 hours on Memorial Day. (Hot air temp, black asphalt and stop and go due to accident.) Pretty common values on regular driving because I constantly watch them. With my luck, I assume all will come apart on me.
My gut tells me a seal went somewhere because it started with a little blue smoke (that I happened to suddenly notice) but over the next couple days, it got bigger and thicker where I couldn't help but see it.
My truck had the same symptom you describe, smoke only at acceleration from stop signs and lights. Ended up being an oil leak in the turbo, I believe there is a seal in there that can go bad, but maybe someone else can confirm this. This was a few years ago and was repaired by the dealer under warranty, all they told me was an oil leak in the turbo.
Thanks, Berick.
Could you post or send to mreckowsky@purdue.edu the steps to check the EGR? I looked on the Excel sheet and performed a search on the 6.0 forum but I didn't see it.
Thanks, Berick.
03-07 Ford Powerstroke EGR Valve Removal and Cleaning - YouTube
Just to add to this vid...... make sure when you clean the carbon off that NO CLEANERS go into the tiny vent holes on the upper portion of the EGR valve... it can mess around with how it opens and closes. Also, the black crud should be dry carbon build up.... if it is sopping wet, then you have another problem that will need to be addressed. Worry about that if it is in fact an issue.
Thanks, Berick! The video is fantastic.
I pulled the EGR and it had a lot of build up on it. I cleaned it off including opening the valve and really cleaning the seats.
Following that, the truck would blow out black AND white/blue smoke under acceleration. The black stopped after a short drive but the original problem, white/blue smoke during acceleration after stop sign/light, persists. The smoke wasn't as pronounced as last week but is definitely still there.
I couldn't get new o-rings (except for purchasing a whole intake manifold kit) but found comparables in an o-ring kit for distributors. I plan on ordering new ones from Sinister today.
What else can I diagnose? I'm figuring it's a seal in the turbo but would love to find a way to pinpoint the problem.
Bone dry on the valve. I used a large paperclip and pulled some of the soot out of the manifold where the valve fit in and there was some "shiny/crystal-like" soot I pulled out. I can't say that that was "wet" but I can't say it wasn't either.
I'm not good with smells, unfortunately. (allergies)
Thanks for following on this one.
Well after cleaning the EGR valve the white or white/blue smoke almost went completely away but by the time I pulled into my driveway this evening, it was smoking heavy like before. I will try to have neighbor smell it tomorrow.
Anyone have thoughts on why it would be intermittent like described? EGR cooler bad? Turbo??
definitely dont wan that.
