Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 07-16-2012, 10:31 AM
Byram's Avatar
Byram Byram is offline
Garage is empty, add now
Byram is gaining momentum as a positive member of FTE.Byram is gaining momentum as a positive member of FTE.
Remember - Check The Battery... Update -Bad Battery
I thought that I would post this - Even though it makes me look stupid..
I went out yesterday AM and battery would barely turn - No start... I was at the ranch so no problems (chargers/ equipment to jump with) But, when I installed my Oasis Compressor - I installed a Cole Hersee Battery Isolator and a Aux Battery (Deep Cycle).. So I just pressed the Momentary switch on the isolator and started the truck Normal (Everybody needs this setup - if you don't like being stranded..)
But the point is - I check the voltage on the Battery and it was 10.5X While off/ Charging at 13.8X while running... So I drove back to town - about an hour figuring it would charge - this AM it started but was weak... Came to office & figured I might be buying a new battery. went out & tested again - Volts in mid 10's.. Then I realized that these factory batteries are NOT maintenance free. I have had gel type batteries in most all my trucks/ equipment for years & stupidly haven't been checking this new one. Checked the water - it was low Added - Drove around a little and it seems to be staying 12.7X even after sitting for an hour or so...
So all is good - Just add water!
Just a note - I have been changing the Oil at the Dealer pretty regular - about every 6 weeks & the Package "the Works" they are suppose to check Battery as well as brakes, fluid levels etc.. I'm now guessing that they don't pop the caps & check the water level in the Battery... Last change was June 6th...
But - I get the dumb award for 42,000 miles without personally checking the water in Battery....
__________________
2011 F-250SC XLT
6.2; 3.73 EL; 4x4; BFG M/T 285's; B&W Turnover; Ranch Hand; Oasis XD 4000 OBA & Aux Battery; 5 Star assisted!
"Peace is that brief glorious moment in history when everybody stands around reloading".
  #2 (permalink)
Old 07-16-2012, 01:26 PM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
I wouldn't be ashamed, maintenance free batteries have been around a long time, surprised Ford still uses the "old" ones. Definitely good information!
/the more you know. (lol)
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #3 (permalink)
Old 07-17-2012, 08:25 AM
Mello Mike's Avatar
Mello Mike Mello Mike is offline
2011 Ford F-250
Mello Mike is starting off with a positive reputation.
A good reminder. Thanks.
  #4 (permalink)
Old 07-18-2012, 10:33 AM
Byram's Avatar
Just a follow-up....
After a couple of days - still had some weak starts - So I pulled a "good Battery " out of a Jeep and tried it.. Leaving the Motorcraft battery in the bed of the truck overnight until I can get to Auto Part store...
Checked the Motorcraft when I removed it - Showed 12.4 volts... 7:00 PM Tues. - Weds at 10:00 AM I put a meter on it and it had fallen to 10.3 volts - just sitting in bed of truck with nothing touching it...
__________________
2011 F-250SC XLT
  #5 (permalink)
Old 07-18-2012, 11:28 AM
Mello Mike's Avatar
2011 Ford F-250
Time for a new battery.
  #6 (permalink)
Old 07-18-2012, 03:37 PM
Byram's Avatar
Quote:
Already in.... My thoughts exactly -
__________________
2011 F-250SC XLT
  #7 (permalink)
Old 08-18-2012, 10:48 PM
jfk42367 jfk42367 is offline
jfk42367 is starting off with a positive reputation.
Where do you have the aux battery located?
  #8 (permalink)
Old 08-20-2012, 07:10 AM
Byram's Avatar
Quote:
I built a frame to hold a battery box under the passenger door. Attached to the frame..
__________________
2011 F-250SC XLT
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
