Fuel pumps problem
It will not run at all if the high pressure pump is not working.
You can have someone turn on the key when you are under the truck and you should hear the selected in-tank low pressure boost pump and the high pressure pump run for one second each time the key is turned from off to on.
The high pressure pump is located on the frame.
Your fuel system:
Your fuel system:
Keep in mind there will be no power to the pumps after the first 1-2 seconds when you turn the ignition key to the On position. Once you start to crank the PCM (engine computer) receives pulses from the stator (aka PIP) inside the distributor. This signal triggers the PCM to turn on the Fuel Pump Relay as well as starts the ignition process.
If you want to turn on Fuel Pump power 100% to diagnose your issue connect pins 2 & 6 on the Diagnostic Link connecter under the hood. Bil has some great info in this thread:
https://www.ford-trucks.com/forums/9...problem-2.html
anthonym92
05-31-2017 05:38 PM
dustmote
11-19-2011 03:08 PM
EPNCSU2006
19
12-19-2003 03:57 PM
mrbooka
02-25-2002 10:41 PM
