building up the 410...
soo, its time to start ordering parts and get ready to rebuild the 410. but still undecided on a few things, like the appropriate compression ratio, pistons/rods, rockers, and so on.
really just lookin for ideas and opinions at the moment.
i have allready done the performance bolt ons, name it it is probably there, or at least under my bed.
so first big question: compression ratio! what to shoot for,what i dont want to go above.
running pump gas is a must.
truck is a 4wd f-100 will have 33" tires. no towing, just playing/ daily driver and some more playing!!!
Since you said pump gas is a must, I'd say the CR needs to no higher than 10.5:1, or you could run into pinging issues. Even at 10.5, you're going to need the timing curve dialed in just right.
The good news is, stock 410/390 truck pistons will get you into that ballpark on stock 390/410 rods.
Going over 10.5:1 CR can be done, and keep it on pump gas, but it usually needs the upper end stuff.
Stock 410s were 10.5, so your head gasket and cc volume, and IF those pistons are made the same will determine what you end up with.
FE Series Engine Specification Chart
ok so at the moment i am looking at
Probe pistons about 10.4:1 (30 over)
Scat H-beam rods
Comp cams XE274H
Holley off road carb, 670 or 770 cfm... still undecided
oh! rocker arms i forgot! roller or not???
i donthave any experience w/ rollers, are they reliable? who to stay away from, whats the best choice?
should i look into a new flywheel? or is the old stocker just fine?
Scat H-beam rods
Comp cams XE274H
Scat H-beam rods
Comp cams XE274H
Scat H-beam rods
Comp cams XE274H
Roller rockers are not a must in my opinion as well. As for carb definitely go with the 670!!!!
I had a new 770 TA on my 428 with similar parts and compression and it had a major top end flat spot where it lagged. Holley tech said the motor I had was too small and didn't have enough velocity to pick up the ball in the metering block. Even the 770 comes with a 2.5 powervalve setup for an extreme cam.
They suggested a 670 and now it's a whole new animal. Good power through all rpm range.
Good luck!
Good luck!
I concur. Unless you're going to winding it pretty tight, the H beam rods and roller rockers would just be bragging rights. Costly ones at that.
My stock ones should be fine and the shop took a few hundred bucks off bill
