Hi guys I need help and fast im removing my hpop to replace to o rings and cant seem to find the 2 10mm bolts holding the hpop on. I have removed the fuel bowl and hpop resivor along with the drive gear bolt.
Thanks everyone ended up finding them on my own. Wish that Clay had put one of those pictures on his instructions. other that that little problem everything worked out good. Hope that it stops the oil leaks i have been having. the worst O rings were inside the discharge fittings. Oh well thanks everyone again!
Stripped the one right beside the IPR, good thing I didn't crack the front cover.
It's fixable, but it's not an easy fix, take it from me...
I stripped the same one. And you're right. The fix is not easy, but beats the hell out of pulling the engine to replace the front cover.
Clay told me to contact Joey at TE and Joey told me about the Fastenal steel insert fix (better than a helicoil). Clay can now supply the inserts, drll bit and taps to make the repair.
You bet I did and knock on wood, it's still holding!
Clay was kind enough to answer a call and 1:00 in the morning as he was boarding a plane to help me with this. He referred me to Joey, who in turn recommended the fix.
It took time and really steady hands, but shes good to go!
So you over torqued the bolt?
I don't think I want to be in that position if I rebuild my HPOP. Hopefully the instructions give the torque specs and not leave it up to me to determine since I am not so good at "tightening by sense".
