223 6cyl rebuild question
Old 07-18-2012, 09:19 AM
OnlyAGeologist's Avatar
OnlyAGeologist
OnlyAGeologist is offline
I have a 1959 F100 with the 223 6cyl I bought last year, PO said it had had its engine worked over previously. How can I easily tell if the engine needs to be rebuilt?
Old 07-18-2012, 09:56 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Do a compression test to check the top end. If you haven't done this before, try youtube. Seems there's lots of instructional videos there. Is there blue smoke? How about blowby? Remove the oil filler cap while it's running. Does it blow out oil and have pressure? Now thread in a mechanical oil pressure gauge in place of the oil pressure light sender. With it warmed up, see what the OP is. The factory service manual will have the specs, but without looking, 15 psi at idle should be okay. I have one truck that idles at about 5 psi and it still has some life in it..... Oh, and welcome to the fridge group. And you happened to get the best year , 1959!
Denbar
18
12-05-2022 07:47 AM
O'Mahony
20
04-17-2019 01:55 PM
Vegas123
10-02-2015 07:43 AM
Reds Eddie
06-18-2008 01:42 PM
Deadeye1963
10-26-2004 11:23 PM
Quick Reply: 223 6cyl rebuild question
