Ford 226 Oil Pressure on a Rebuild
Old 09-25-2015, 09:53 AM
Vegas123
Vegas123 is offline
Vegas123 is starting off with a positive reputation.
Hello,
So I finally got around to starting up my recently rebuilt ford 226. Upon starting it up I noticed that the oil pressure went up to 80 pounds at idle. But on giving her a little gas oil pressure went beyond the gauge readings, looks like its well beyond 100 psi. Oil pressure remains beyond 100. I am using a mechanical gauge and today hooked up a second one to confirm the readings from the first, it does the same thing.
What could be causing this?? I have only ran the motor 2 times and around 5 min each time.
Old 09-25-2015, 10:01 AM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
ALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputationALBUQ F-1 has a superb reputation
I'd guess your oil pressure relief valve is stuck shut. Lots of details on it in this old thread:
https://www.ford-trucks.com/forums/1...aight-6-a.html
Old 09-25-2015, 11:27 AM
96XL
96XL is offline
96XL is gaining momentum as a positive member of FTE.96XL is gaining momentum as a positive member of FTE.
what weight oil are you using?
Old 09-25-2015, 03:26 PM
Vegas123
Vegas123 is offline
Thanks for the tip Ross.
I will check which break in oil I am running tonight.
Thanks
Old 09-25-2015, 08:58 PM
Vegas123
Vegas123 is offline
I am running 15 w-50 break in oil by Joe Gibbs.
Before trying to remove the pressure relief valve I went out back to practice on my old block.
I broke 2 screw drivers.
What is the best way to remove this valve?? Looks like I may need a super size screw driver? I only fear that I may chew up the slotted end before I comes out.
Any ideas???
I was also thinking may be before removing it I try and add some wd40 into the plug right above to try and loosen it up. What do you guys think?
Old 09-25-2015, 09:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
WD-40 isn't a good penetrant; for an oil system component all gummed up, I'd try straight acetone or lacquer thinner. They make "screwdriver bits" for 3/8" ratchets/breaker bars, likely what you'll need. The hot wrench may help too.
Old 09-26-2015, 10:23 PM
3twinridges's Avatar
3twinridges
3twinridges is online now
3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all3twinridges is a name known to all
to remove that valve I used a big 3/8 flathead screwdriver, the biggest one they sell at Lowes in conjunction with a little heat from a mapp torch. The same does not work on the galley plugs so I have a 1/2 flathead socket coming for the impact gun.
Jb
Old 09-27-2015, 01:45 PM
Vegas123
Vegas123 is offline
Thanks for your help!
Old 10-01-2015, 07:45 PM
Vegas123
Vegas123 is offline
So as you can see from the picture, the valve stem is jammed and will not move in the relief valve that I just removed from the rebuild block.
I removed the other relief valve from the 226 block i have on the side of my house.
Thanks Everyone for the tip, looks like the relief valve is stuck closed.
I will try to loosen it up and clean it, or just use the one from my other block.
Old 10-01-2015, 09:43 PM
Vegas123
Vegas123 is offline
PSI now at 50, I only ran it for 1 minute to see if it would go to 100.
Thanks God it Did Not!
Old 10-01-2015, 10:07 PM
pineconeford's Avatar
pineconeford
pineconeford is online now
pineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant futurepineconeford has a brilliant future
Vegas,
What RPM did you observe the 50?
And did you note any other readings after the fix at any other RPM's?
Reason for asking, I'm wondering what I could expect to see on my 226 if it were rebuilt.
thanks for any info,
Tom
Old 10-02-2015, 07:43 AM
Vegas123
Vegas123 is offline
Hi Buddy,
I am sorry I cannot give much more details since I only ran the engine for about 1 minute. It reached approx 50 pounds at cold start. I do not have an RPM gauge set up, sorry.
I will update this post as I go and let you know how the oil pressure thing goes.
hobo99
11-21-2016 05:36 PM
GreenMM
1968-2013 Full Size Vans
43
04-21-2016 09:15 AM
maf226
02-22-2016 08:59 AM
brain75
31
02-05-2016 06:01 PM
Quick Reply: Ford 226 Oil Pressure on a Rebuild
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
